Discuss
Freezer freezes, refrigerator not cooling
 in
Refrigerator & Freezer Repair
Hi, this frig worked great while we were at our old address. The frig was put into storage for about
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer freezes, refrigerator not cooling
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-16-2007, 12:57 PM
redeyedog redeyedog is offline
Junior Member
redeyedog is on a distinguished road
Default Freezer freezes, refrigerator not cooling
Model Number: ET18TKXDW05   Brand: Whirlpool   Age: 5 - 10 years
Hi, this frig worked great while we were at our old address. The frig was put into storage for about 6 months. After putting it into operation at our new place, it seems that the defrost fan never kicks on although the freezer is cold enough to keep things frozen. Some frost builds.
The refigerator is a problem. No matter what settings we try, the frig doesn't cool. Milk went bad in 3 days.
So far, this is what I have done.
1. Cleaned the condensor coils on the bottom of the frig.
2. Removed the back panel and cleaned everything and checked for loose connections.
3. When I turn off the refrigerator knob in the frig, the condensor fan shuts off. When I turn it on, the fan runs and seems to run forever.
4. While the back cover was off, I observed that the compressor (I think - big round tub thing) was kinda hot to the touch.
Note: I moved the frig myself and I know it wasn't mishandled so I cannot imagine that moving it caused the damage.
Any ideas on how I might get normal operation restored. I'm a computer technician but I don't know jack about refrigerators.
Any help would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-17-2007, 02:10 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull the back freezer panel and look for any frost, if a little frost,you have major refrigeration problems requiring a tech. If no frost, you may just have a bad start relay. Pull off plastic cover on the side of compressor and pry off the relay.Test it with an ohm meter, if blown open you can get it at appliancepartspros. P# ap3108669
__________________
  #3 (permalink)
Old 09-17-2007, 10:40 AM
Junior Member
Default How?
Thanks for your ideas. I have a volt meter/ohm meter and I'm looking in the Whirlpool owner's manual parts list for this model and cannot find anything called a start relay.
There are two parts, 2149959 Production (Includes Relay) and 2154759 Service (Includes Relay) under the 2162358 Cover. I believe you are referring to one of these. There is no ice behind the back cover.
The temperature in the freezer is -15F, the refrigerator is 47F when the temperature knobs are both set to recommended settings which is 3 on both sides.
Unfortunately, your ap part number and picture do not give me much to go by. When testing the part, exactly what am I looking for?
  #4 (permalink)
Old 09-17-2007, 04:56 PM
Senior Expert
APP Volunteer
Default
You are looking for a blown open relay. It will have no continuity at all.That's the big box that plugs into the compressor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator not cooling, but freezer is working geri Refrigerator & Freezer Repair 16 12-27-2007 10:13 PM
Refrigerator freezes everything Susan Refrigerator & Freezer Repair 4 09-21-2007 06:14 AM
freezer freezes but fridge is warm billybob Refrigerator & Freezer Repair 1 09-13-2007 02:50 AM
refrigerator freezes fresh food rondawn Refrigerator & Freezer Repair 1 09-06-2007 12:01 AM
refrigerator not cooling after being moved phyllisstowe Refrigerator & Freezer Repair 0 08-23-2007 12:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
