The frigerator worked great up till 3 months ago it said if there was sweat on the outside of frige to change to the non energy saver swich I did and it worked great for about 2 months, then sweat started to be all over the inside of the frige also and it was not keeping things very cold at all. Still that way now. I would guess it is around 60-70 degrees in there now. The freezer is not the greatest now either but still is keeping things frozen. The setting inside the frige is now at 9. The freezer is at f-g I noticed this morning that I could feel cold air excaping the freezer around the bottom weather stripping and i put a large piece of insulation around that part till i could no longer feel air. Im going to wait 24 hours and see if that makes a differance also. Please help!!
Are condensing coils under refrigerator? If so, they might be clogged with dust.
