| » inside leaker |
Model Number: GTS22JCP Brand: GE Age: 1 - 5 years
Why does my refrigerator leak inside from the hole in the upper right side of my refrigerator. After a while, the water flows out of my frige door.. I have the Ice maker tray inside the freezer part of the refrigerator. John
That is because you defrost drain hole is plugged up, and when the refer goes into defrost instead of it going down the drain it runs out to the freezer fllor and down into the freshfood section.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
To fix, you will need to remove the back of the freezer section, use hot water an a turkey baster to clear the drain located under the evaperator.
__________________
| Display Modes | |
| how to get inside to fix? | nsherra | Washer Repair | 0 | 06-18-2008 11:02 AM |
| inside a maytag | bobb | Dryer Repair | 0 | 04-23-2008 07:21 AM |
| Advantium inside light | edgineer | Microwave Repair | 1 | 01-26-2008 08:40 PM |
| Removing the cam inside the agitator. | AnnM | Washer Repair | 1 | 11-19-2007 08:08 PM |
| Drip from Inside at the Top | KC John | Washer Repair | 0 | 07-27-2007 09:31 AM |
