Two problems exist. The first is a constant dripping in the refrigerator compartment from the overhead console towards the rear. I unscrewed the unit and removed to check for blocked drain and it was fine. The second problem is the temp settings. they are both at the recommended midpoints but the reefer doesn't cool properly. If the thermostat is set to a cooler setting the food & beverage items tend to freeze in the reefer section. Are the two problems related?
