2 Pages<12
jaq1959
#11 Posted : Friday, August 15, 2008 6:47:13 PM(UTC)
jaq1959
I just plugged unit back in and compressor starts for about 5 seconds then shuts off.
libertyappl
#12 Posted : Friday, August 15, 2008 6:55:36 PM(UTC)
libertyappl
Ok then either your start relay is out or your compressor one. I suggest unpluggin it until you either have a tech look at it get a relay (I'd replace the realy, start device and the capacitor)You can get a universal combo to check it part number AP3540659. Which would probably be cheaper than a service call they come with instructions to hook them up. If that works then you could get the OEM parts or leave the universal on the unit. If that doesn't actually turn the compressor over then I'm afraid it's your compressor and depending on where you are the cost ranges. We do them for around $500. but we are also in a very rural area larger areas charge a lot more.
Nat
jaq1959
#13 Posted : Friday, August 15, 2008 7:01:59 PM(UTC)
jaq1959
Is there a way I can check components with my ohm meter?
libertyappl
#14 Posted : Friday, August 15, 2008 7:11:35 PM(UTC)
libertyappl
yes there is, I'd have to look up the process for you. We find it easier to test with a universal 3 in 1 combo.
You might check out this other thread.
http://forum.appliancepartspros...continuity-ohmmeter.html
But i would defiantely UNPLUG your refrigerator, if not unplugged and it's the start device it WIL be your compressor soon. It will burn it up trying to start.
Hope that helps.
jaq1959
#15 Posted : Friday, August 15, 2008 7:17:18 PM(UTC)
jaq1959
I will try universal combo. What does this consist of? Thank you so much for your help.
libertyappl
#16 Posted : Friday, August 15, 2008 7:25:09 PM(UTC)
libertyappl
It's basically removing the start device/relay and capacitor and follow instructions on the universal. Here's the part number again AP3540659
This is probably the cheapest place to get one, unless you have an appliance part store nearby to get one quicker.
You're welcome. Post your results if you would, helping you helps me too!!
Nat
jaq1959
#17 Posted : Friday, August 15, 2008 7:27:43 PM(UTC)
jaq1959
I will post as soon as I try combo. Thank you again. Very helpfull!
Frigidaire Freezer Compressor Hot (Refrigerator & Freezer Repair)
by swglenn 10/25/2015 5:32:56 AM(UTC)
refrigerator not cooling, compressor hot (Refrigerator & Freezer Repair)
by kathymc 5/5/2015 6:28:46 PM(UTC)
Compressor Hot - Fridge not always so cool (Refrigerator & Freezer Repair)
by sgsiegel 6/11/2014 10:13:46 AM(UTC)
fridge not freezing/cooling. compressor hot but running (Refrigerator & Freezer Repair)
by fraysergreg1971 5/30/2014 7:10:11 PM(UTC)
compressor hot/not running. (Refrigerator & Freezer Repair)
by sambocd8 3/19/2014 4:46:53 PM(UTC)
Freezer fan running, compressor hot, but not running (Refrigerator & Freezer Repair)
by lpan71 1/8/2014 9:55:37 AM(UTC)
Refrigerator not cooling, compressor hot (Refrigerator & Freezer Repair)
by Twclark06 12/17/2013 7:51:21 AM(UTC)
Compressor hot – fridge not cooling (Refrigerator & Freezer Repair)
by debenriver 11/13/2013 1:42:56 PM(UTC)
Igloo FR834 Mini Fridge not cooling and compressor HOT (Refrigerator & Freezer Repair)
by pentester101 7/25/2012 11:21:09 AM(UTC)
not cooling, compressor hot, fan working (Refrigerator & Freezer Repair)
by adam_white 6/13/2012 12:32:03 PM(UTC)
compressor hot and not running (Refrigerator & Freezer Repair)
by Vinch 3/5/2012 2:45:48 PM(UTC)
Compressor hot & no cool freezer (Refrigerator & Freezer Repair)
by Kingbled 11/3/2011 1:42:56 AM(UTC)
GE Profile fridge compressor hot and not running (Refrigerator & Freezer Repair)
by ProjectMan 8/17/2011 12:42:52 PM(UTC)
Fridge/Freezer Not Cooling, Compressor Hot (Refrigerator & Freezer Repair)
by ryanej 4/20/2011 5:40:52 PM(UTC)
Refrigerator not cooling, fan working, compressor hot but not running (Refrigerator & Freezer Repair)
by Andreyvol 2/28/2011 6:55:49 PM(UTC)
2 Pages<12
