Discuss
Side by side cold freazer and fridge, hot inner wall!
 in
Refrigerator & Freezer Repair
Replaced the thermostat, Fridge still gets hot to the touch on the divider wall between the fridge and freezer. So
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Side by side cold freazer and fridge, hot inner wall!
  #1 (permalink)
Old 08-15-2008, 02:57 PM
gaber79 gaber79 is offline
Junior Member
gaber79 is on a distinguished road
Default Side by side cold freazer and fridge, hot inner wall!
Model Number: 106.51552101   Brand: Kenmore   Age: 5 - 10 years
Replaced the thermostat, Fridge still gets hot to the touch on the divider wall between the fridge and freezer. So hot that the door of the fridge is hot. Temperature of both fridge and freezer is good but it appears to be running non stop.
Any ideas? Thank you in advance!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-15-2008, 02:59 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
You either have a dirty condensor, or the condensor fan is not running. Take the rear access cover off and verify. Keep me posted.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-18-2008, 06:00 AM
Junior Member
Default
Thank you.
I will check that out as soon as possible and tell you what I find.
Thanks for the lead!
  #4 (permalink)
Old 08-25-2008, 07:54 AM
Junior Member
Default New Condensor fan!!
I put in a new condensor fan and everything is working fine now. Thank you for your help! The coils were not that dusty all though I did clean them with a condensor brush while I was down there.
Also just a quick helpful hint: the listed replacement motor for the condensor fan was $70-$120, found a replacemnt condensor fan motor ($44) for kenmore that had a two wire hookup instead of the plug in that fed the original motor. Three srews that bolted to the bracket instead of the plate->bracket that the original motor fit onto. All is the same electrically and all is working well!
Thaks again for the great help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Side-by-Side Freezer icing, fridge warm barkwaffle Refrigerator & Freezer Repair 0 08-04-2008 08:57 PM
Maytag side by side Freezer cold Refrig warm timbruns Refrigerator & Freezer Repair 2 06-10-2008 06:11 PM
Freezer Cold,But refrig warm (Side/Side) oceanrunner Refrigerator & Freezer Repair 5 12-28-2007 10:19 PM
not freezing but fridge side nice and cold? mommame Refrigerator & Freezer Repair 1 09-10-2007 08:45 PM
fridge side warm but freezer is cold shthd2u Refrigerator & Freezer Repair 1 09-09-2007 12:15 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
