Discuss
Water Dispenser quit working
 in
Refrigerator & Freezer Repair
The water dispenser on my Whirlpool side by side quit dispensing water. The ice maker works fine only the water
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water Dispenser quit working
  #1 (permalink)
Old 09-14-2007, 08:08 PM
Junior Member
rhondalrowley is on a distinguished road
Default Water Dispenser quit working
Model Number: GD25DQXFW00   Brand: Whirlpool   Age: 5 - 10 years
The water dispenser on my Whirlpool side by side quit dispensing water. The ice maker works fine only the water dispenser quit working. I do not get anything, no click, no hum no water. I just replaced the water inlet valve thinking that was the problem, but, still not working. I did notice before it quit I was getting air in the line. Any help?
Ads By Google
Related Models
Whirlpool GD25DQXFW00
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
Whirlpool GD27DFXFW00
Whirlpool GD27DFXFW01
Whirlpool GD27DFXFW02
Whirlpool GD27DFXFW03
Whirlpool GD27DIXHB00
Whirlpool GD27DIXHB01
Whirlpool GD27DIXHB02
Whirlpool GD27DIXHS00
Whirlpool GD27DIXHS01
Whirlpool GD27DIXHS02
Whirlpool GD27DIXHT00
Whirlpool GD27DIXHT01
Whirlpool GD27DIXHT02
Whirlpool GD27DIXHW00
Whirlpool GD27DIXHW01
Whirlpool GD27DIXHW02
Whirlpool GD27DQXFB00
Whirlpool GD27DQXFB01
Whirlpool GD27DQXFN00
Whirlpool GD27DQXFN01
Whirlpool GD27DQXFW00
Whirlpool GD27DQXFW01
Whirlpool GD2LHGXKB00
Whirlpool GD2LHGXKQ00
Whirlpool GD2LHGXKT00
Whirlpool GD2LHGXLB00
Whirlpool GD2LHGXLB01
Whirlpool GD2LHGXLB03
Whirlpool GD2LHGXLB04
Whirlpool GD2LHGXLQ00
Whirlpool GD2LHGXLQ01
Whirlpool GD2LHGXLQ03
Whirlpool GD2LHGXLQ04
Whirlpool GD2LHGXLT00
Whirlpool GD2LHGXLT01
Whirlpool GD2LHGXLT03
Whirlpool GD2LHGXLT04
Whirlpool GD2NHAXMB00 Refrigerator
Whirlpool GD2NHAXMQ00 Refrigerator
Whirlpool GD2NHAXMT00 Refrigerator
Whirlpool GD2NHGXKB01
Whirlpool GD2NHGXKB02
Whirlpool GD2NHGXKQ01
Whirlpool GD2NHGXKQ02
Whirlpool GD2NHGXKT01
Whirlpool GD2NHGXKT02
Whirlpool GD2NHGXLQ00
Whirlpool GD2NHGXLT00
Whirlpool GD2SHAXKB01
Whirlpool GD2SHAXKB02
Whirlpool GD2SHAXKB03
Whirlpool GD2SHAXKQ01
Whirlpool GD2SHAXKQ02
Whirlpool GD2SHAXKQ03
Whirlpool GD2SHAXKT01
Whirlpool GD2SHAXKT02
Whirlpool GD2SHAXKT03
Whirlpool GD2SHAXLB00
Whirlpool GD2SHAXLB02
Whirlpool GD2SHAXLQ00
Whirlpool GD2SHAXLQ02
Whirlpool GD2SHAXLT00
Whirlpool GD2SHAXLT02
Whirlpool GD2SHAXMB00 Refrigerator
Whirlpool GD2SHAXMQ00 Refrigerator
Whirlpool GD2SHAXMT00 Refrigerator
Whirlpool GD2SHAXNB00 Refrigerator
Whirlpool GD2SHAXNB01 Refrigerator
Whirlpool GD2SHAXNL00 Refrigerator
Whirlpool GD2SHAXNL01 Refrigerator
Whirlpool GD2SHAXNQ00 Refrigerator
Whirlpool GD2SHAXNQ01 Refrigerator
Whirlpool GD2SHAXNS00 Refrigerator
Whirlpool GD2SHAXNS01 Refrigerator
Whirlpool GD2SHAXNT00 Refrigerator
Whirlpool GD2SHAXNT01 Refrigerator
Whirlpool GD2SHGXKB01
Whirlpool GD2SHGXKB02
Whirlpool GD2SHGXKQ01
Whirlpool GD2SHGXKQ02
Whirlpool GD2SHGXKT01
Whirlpool GD2SHGXKT02
Whirlpool GD2SHGXLB00
Whirlpool GD2SHGXLB01
Whirlpool GD2SHGXLQ00
Whirlpool GD2SHGXLQ01
Whirlpool GD2SHGXLT00
Whirlpool GD2SHGXLT01
Whirlpool GD2SHKXKQ00
  #2 (permalink)
Old 09-15-2007, 03:04 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You might have a frozen water line in the door. Check your freezer temperature, if below zero, adjust your freezer control for a higher temperature.
Also, you can remove the dispenser housing and add insulation around the water line, or just rout further away from the inner panel.
Clogged condenser coils may also cause this problem.
__________________
  #3 (permalink)
Old 09-15-2007, 08:09 AM
Junior Member
Default
I know the water line is not frozen. Someone mentioned a control bracket but I do not know where that is located. I still feel I should hear a noise when I push the bracket. Like a hum or a click?
  #4 (permalink)
Old 09-16-2007, 02:22 AM
Senior Expert
APP Volunteer
Default
You might have a bad micro switch in the door. Put meter on valve and have someone push the water dispenser. No voltage will verify a bad switch or wiring problem.
__________________
  #5 (permalink)
Old 09-25-2007, 09:14 PM
Junior Member
Default Found my problem
For anyone who has a ice/water dispenser in the door of their Whirlpool and your water quits dispensing, here are a few tips. First I was told to try the water valve located at the back of the fridge. Not the problem. Then I was told to check the freezer door, remove the screw out of the top and check the wiring. Not the problem and not very common. Then I was told to take of the front cover. VERY tricky. 99 out of 100 times you break the cover and it's EXPENSIVE. Why did Whirlpool make that so complicated? Got the cover off without breaking it... and found the problem. It was the bracket control. Very cheap part Whirlpool put in. Plastic! All I had to do was insert the new bracket and WOW now I have water.
  #6 (permalink)
Old 08-07-2008, 07:08 AM
Junior Member
jcinar is on a distinguished road
Default I the have same problem. My solution
Quote:
The control bracket which holds the micro switches is made of molded plastic and breaks easily. On mine the part of the bracket that holds the switch for the water dispenser broke and the switch is then too loose to be operated by the dispenser lever. Pop off the molding around the dispenser and you will see the control bracket and switches and can then diagnose your problem.
To remove the molding use a butter or table knife (not sharp) and slip it under the molding at the bottom to pry it off. Once the bottom releases push down on the top of the molding while pulling and twisting on the loose bottom and the top should release. It is then easy to get to all the working parts for the dispenser.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water dispenser quit ronsmart88 Refrigerator & Freezer Repair 0 11-11-2009 12:40 PM
Ice dispenser quit working rjganzel Refrigerator & Freezer Repair 0 08-28-2009 10:53 AM
Water dispenser quit working asidpara Refrigerator & Freezer Repair 0 06-06-2009 03:33 PM
Water dispenser in door quit working sewcaps@aol.com Refrigerator & Freezer Repair 3 09-22-2008 06:25 PM
water dispenser quit working krisshan Refrigerator & Freezer Repair 0 01-19-2008 04:04 PM
