Discuss
Bosch Ref. Ice maker
 in
Refrigerator & Freezer Repair
Hi side by side ref. freezer. will not produce adequate quanity of ice , , neighbor has same ref. in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Bosch Ref. Ice maker
  #1 (permalink)
Old 07-26-2010, 08:04 AM
Junior Member
Gibone is on a distinguished road
Default Bosch Ref. Ice maker
Brand: Bosch   Age: 1 - 5 years
Hi side by side ref. freezer. will not produce adequate quanity of ice , , neighbor has same ref. in her house and complains of sme problem.
. water line seems AOK.
Ads By Google
  #2 (permalink)
Old 07-26-2010, 09:33 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Since you did not supply a model number, I can only give you general information.
On average and under ideal conditions, it takes approximately 60 minutes to produce a batch of ice cubes after the previous cubes drop into the bucket(approximately 90 minutes from start to start of the cycle)
The ice maker only produces 8 cubes at a time.
The freezer product(food) temperature should be 0 degrees(+ or-3 degrees) for ideal ice production and food retention.
You may want to check your owners manual for a more indepth explanation and diagnosis for a possible problem, since usage has a great effect on customer expectations.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-27-2010, 05:31 PM
Junior Member
Default
the Model # of this Bosch Refridgerator B2OCS80SNS /02
WE believe this is a common problem with this product.
  #4 (permalink)
Old 07-27-2010, 05:33 PM
Junior Member
Default
Bosch ref. and frezzer ( Ice maker ) not making ice continualy what part could be broke . if any. or is it just 8 cubes and that slow the unit is less than 2 years rd.
  #5 (permalink)
Old 07-28-2010, 06:52 AM
Senior Expert
Default
Sorry, but,
There are no broken parts(at this point).
As I stated before, in general all ice makers used in refrigerators today take 60 to 90 minutes(60 minutes average), to produce a batch of ice cubes(8 cubes).
Some brands and models do have selections or options that can increase ice production to as quick as 40 minutes(average).
If you wish to test the production: empty the bin and let the ice maker produce ice for a 10 to 12 hour period. at an average of 8 cubes an hour, you should have 80 to 96 cubes.
This is the way the ice maker is designed to operate.
If there is a major shortage of cubes, then you may have a freezer temperature thats not cold enough(0 degree farenheit).
It may be time to replace the water filter in the refrigerator or on the water supply line,it needs to be replaced at least once a year.
Poor air flow due to too much food product in either compartment.
Poor water flow from the water supply line to the refrigerator itself,wrong water temperature(Make sure water supply line is from a cold water pipe,not accidentally on the hot supply line).
I hope this expanded explanation helps.
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 10-18-2011, 07:30 AM
Junior Member
jimmyG7272 is on a distinguished road
Default Ice Maker stopped making Ice
I have model # B20cs50sns and my ice maker started slowly producing less ice and taking a long time. Now no ice at all? Help!
  #7 (permalink)
Old 10-18-2011, 08:45 AM
Senior Expert
Default
Quote:
Jimmy,
Had difficulty with the model number you supplied. but ,
You need to start by checking the water filter in the refrigerator, it could be clogged or restricted with sediment, and the water inlet valve, it could have a restriction, or a solenoid has failed and will not allow the water into the icemaker.
Good Luck and Thanks,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch ice maker heater ktrammel Refrigerator & Freezer Repair 0 02-09-2010 08:37 AM
New ice maker installed but no water running to ice maker corona32guiness Refrigerator & Freezer Repair 0 01-06-2010 05:14 PM
Ice Maker water is dispensing into the bin instead of into the cube maker jghani Refrigerator & Freezer Repair 0 09-12-2009 10:20 AM
GE tube ice maker freezing but ice maker works dhayden Refrigerator & Freezer Repair 1 09-05-2009 08:54 AM
Replaced Ice Maker and noid and still no water to ice maker darrewhite Refrigerator & Freezer Repair 0 05-17-2009 06:34 AM
