Hello, No water coming to icemaker. No frozen water in line and not blocked. Bin is empty and arm is in lower position. Chillled water to door works fine. Removed valve and icemaker solenoid is 236 ohms and water solenoid is 355 ohms. Freezer is 10 degrees.
Do readings on valve seem ok? If so how to test the icemaker sending signal?
thanks Ray
