Discuss
Water dispenser tube broken
 in
Refrigerator & Freezer Repair
I read how to remove the front panel of the refrigerator by inserting a screwdriver blade in the slots on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water dispenser tube broken
  #1 (permalink)
Old 07-25-2010, 02:06 PM
Junior Member
glwood6 is on a distinguished road
Default Water dispenser tube broken
Model Number: ED22RFXFN00   Brand: Whirlpool   Age: 5 - 10 years
I read how to remove the front panel of the refrigerator by inserting a screwdriver blade in the slots on the bottom of the panel then twisting, then sliding the panel up to remove; is that the proper method for my model number also? Then, does the entire water line need to be replaced, or can the end plastic nozzle be replaced only? I found part number AP3108776 as the replacement part on appliancepartspros.com, but it includes quite an amount of tubing as well as the plastic nozzle, hence my question. Is replacing the nozzle only an option?
Ads By Google
Related Models
Whirlpool ED22RFXFN00
Whirlpool ED22RFXFN01
Whirlpool ED22RFXFN02
Whirlpool ED22RFXFN03
Whirlpool ED22RFXFN04
Whirlpool ED22RFXFW00
Whirlpool ED22RFXFW01
Whirlpool ED22RFXFW02
Whirlpool ED22RFXFW03
Whirlpool ED22RFXFW04
Whirlpool ED22RKXXW00
Whirlpool ED22RKXXW01
Whirlpool ED22RQXWW00
Whirlpool ED22RQXXW00
Whirlpool ED22RQXXW01
Whirlpool ED22TEXHN00
Whirlpool ED22TEXHN01
Whirlpool ED22TEXHN02
Whirlpool ED22TEXHN03
Whirlpool ED22TEXHN04
Whirlpool ED22TEXHT02
Whirlpool ED22TEXHT03
Whirlpool ED22TEXHT04
Whirlpool ED22TEXHW00
Whirlpool ED22TEXHW01
Whirlpool ED22TEXHW02
Whirlpool ED22TEXHW03
Whirlpool ED22TEXHW04
Whirlpool ED22TQXEN00
Whirlpool ED22TQXEN01
Whirlpool ED22TQXEW00
Whirlpool ED22TQXEW01
Whirlpool ED22TQXFN00
Whirlpool ED22TQXFN01
Whirlpool ED22TQXFW00
Whirlpool ED22TQXFW01
Whirlpool ED22TQXGN00
Whirlpool ED22TQXGW00
Whirlpool ED22TWXDN00
Whirlpool ED22TWXDN01
Whirlpool ED22TWXDN02
Whirlpool ED22TWXDW00
Whirlpool ED22TWXDW01
Whirlpool ED22TWXDW02
Whirlpool ED22UEXHN02
Whirlpool ED22UEXHT00
Whirlpool ED22UEXHT01
Whirlpool ED22UEXHT02
Whirlpool ED22UEXHW00
Whirlpool ED22UEXHW01
Whirlpool ED22UEXHW02
Whirlpool ED22UQXGN00
Whirlpool ED22UQXGN01
Whirlpool ED22UQXGW00
Whirlpool ED22UQXGW01
Whirlpool ED22ZMXPWR0
Whirlpool ED22ZRXAN00
Whirlpool ED22ZRXAW00
Whirlpool ED22ZRXBN00
Whirlpool ED22ZRXBN01
Whirlpool ED22ZRXBW00
Whirlpool ED22ZRXBW01
Whirlpool ED22ZRXDN00
Whirlpool ED22ZRXDN01
Whirlpool ED22ZRXDW00
Whirlpool ED22ZRXDW01
Whirlpool ED22ZRXXN00
Whirlpool ED22ZRXXN01
Whirlpool ED22ZRXXW00
Whirlpool ED22ZRXXW01
Frigidaire ED258K6 Wwh(v2) / Electric Dehumidifier
Frigidaire ED258K6A Wwh(v1) / Dehumidifier
Frigidaire ED258K6B Wwh(v1) / Dehumidifier
Whirlpool ED25CEXJB00
Whirlpool ED25CEXJB01
Whirlpool ED25CEXJT00
Whirlpool ED25CEXJT01
Whirlpool ED25CEXJW00
Whirlpool ED25CEXJW01
Whirlpool ED25CQXFB00
Whirlpool ED25CQXFB01
Whirlpool ED25CQXFB02
Whirlpool ED25CQXFN00
Whirlpool ED25CQXFN01
Whirlpool ED25CQXFN02
Whirlpool ED25CQXFW00
Whirlpool ED25CQXFW01
Whirlpool ED25CQXFW02
Whirlpool ED25CQXHB00
Whirlpool ED25CQXHB01
Whirlpool ED25CQXHB02
Whirlpool ED25CQXHB03
Whirlpool ED25CQXHN00
Whirlpool ED25CQXHN01
Whirlpool ED25CQXHN02
Whirlpool ED25CQXHN03
Whirlpool ED25CQXHT00
Whirlpool ED25CQXHT01
Whirlpool ED25CQXHT02
Whirlpool ED25CQXHT03
Whirlpool ED25CQXHW00
Whirlpool ED25CQXHW01
Whirlpool ED25CQXHW02
Whirlpool ED25CQXHW03
Whirlpool ED25DQXAB00
Whirlpool ED25DQXAB01
Whirlpool ED25DQXAN00
Whirlpool ED25DQXAN01
Whirlpool ED25DQXAW00
Whirlpool ED25DQXAW01
Whirlpool ED25DQXBB00
Whirlpool ED25DQXBB01
Whirlpool ED25DQXBN00
Whirlpool ED25DQXBN01
Whirlpool ED25DQXBW00
Whirlpool ED25DQXBW01
Whirlpool ED25DQXDB00
Whirlpool ED25DQXDB01
Whirlpool ED25DQXDB02
Whirlpool ED25DQXDB04
  #2 (permalink)
Old 08-01-2010, 01:36 PM
Junior Member
Default
Thanks for all the valuable input.
I fixed it myself, at least for now. I am such a cheapskate, I couldn't see spending $40+ for a piece of plastic tubing with a little plastic flange on the end that screws to the bracket. I undid the screw that holds the water dispenser tube in the door opening, then disconnected the waterline under the freezer door, and pushed the water line up about 4".
I cut the tubing off the back of the face flange about 3/8" back, and notched the locating tab in the back enough for a repair tube. I then cut a 1" piece of 1/4" tubing that is used in garden watering drip systems. I then heated that piece up in boiling water, then slipped it over the fridge tubing pieces, pushing them back together. Re-installed the dispenser tube screw, re-connected the waterline under the door. Done. No more leak.
I will replace my ice door with the kit, though, it is on it's last legs, and I can see needing a new one. That I can deal with.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thru-Door Water Dispenser Tube Replacement K-Dub Refrigerator & Freezer Repair 5 12-22-2012 05:59 PM
Water Dispenser Tube Freezing dfc147fw Refrigerator & Freezer Repair 0 02-05-2010 06:34 PM
water dispenser tube pandatx Refrigerator & Freezer Repair 1 11-30-2009 04:22 AM
Leaking Water Dispenser tube jsharp Refrigerator & Freezer Repair 1 03-31-2009 07:14 PM
Water Dispenser Tube Bruce King Refrigerator & Freezer Repair 0 07-28-2008 12:25 PM
