long story short. I had to replace the motor due to a bad connector. I bought a used one, hooked it up and it worked. The fridge wasnt performing good so i checked the fan and to the best of my knowledge the fan blade is spinning backwards. which way should the air be moving? Should it be blowing down to the coil or should it be pulling the air up from the coil?
