Hi I have a a cooling problem the compressor is not working so i replaced the overload/relay switch when i removed the switch it has a rattle sound installed new switch and still compressor will not kick in one of the lines comming out of compress gets real hot is there something else that could be wrong i think it has a bad compress thanks brad
