Discuss
Many ice problems with GE Fridge
 in
Refrigerator & Freezer Repair
I have a few problems with my GE Fridge. 1. The icemaker is dripping water onto the paddle feeler. That
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Many ice problems with GE Fridge
  #1 (permalink)
Old 08-11-2008, 09:30 PM
AlexKirkpatrick AlexKirkpatrick is offline
Junior Member
AlexKirkpatrick is on a distinguished road
Default Many ice problems with GE Fridge
Model Number: GSS25KGMC WW   Brand: GE   Age: 5 - 10 years
1. The icemaker is dripping water onto the paddle feeler. That keeps it from moving and no more ice is made.
2. The water dispenser decided to intermittently dispense water while I was at work. I got to clean up six gallons when I got home
3. The freezer door gasket needs replaced.
4. The insulation inside the door needs replaced.
5. The trap door does not always close, which causes frost to build up inside the freezer if you don't manually close it.
A repair guy came out today. He discovered problem 3 and while trying to duplicate problem 2, the ice inside the door began to melt all over the floor. When he opened up the door, he discovered problem 4. Here are my questions.
a. I believe a bad switch is to blame for problem 2. Good guess or no? Is there a way to troubleshoot, or should I just replace it at $9?
b. Any suggestions on how to troubleshoot problem 1? Apparently staring at it for 10 minutes doesn't do it and I'm afraid to keep the door open any longer than that.
c. Is it fairly straightforward to replace the insulation?
d. I can't find what part number to order so I can replace the trap door. Any suggestions?
Thanks in advance,
Alex
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-11-2008, 09:49 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
A. Good guess on the switch, replace it. with all the moisture you talk about there is a darn good chance the switch has gotten wet.
B.You need a new icemaker, no way around that one...
C. You can't replace the insulation. This refer was under a class action lawsuit for all the problems you describe which would have been taken care of if reported within the time frame, unfortunatly that time frame has expired. The only way to fix the door is to purchase the new doorkit from GE. About $800 for the repair kit.
D. Part Details - GE Ice door assembly, part number: WR17X11653
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Fridge problems gehrhart Refrigerator & Freezer Repair 1 07-26-2008 03:30 PM
Freezer fridge problems Montgomery Ward Em in Maine Refrigerator & Freezer Repair 1 06-25-2008 01:06 AM
Jenn-Air fridge makes loud noises, has hot sides and sometimes freezes food in fridge timotay714 Refrigerator & Freezer Repair 1 05-05-2008 05:45 PM
Kitchen Aid Fridge KSCS25FKSS00 is freezing on the fridge size shawnharper Refrigerator & Freezer Repair 0 09-03-2007 11:27 PM
Kenmore fridge - water drips into fridge njblue55 Refrigerator & Freezer Repair 3 08-07-2007 08:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
