Discuss
Kitchen Aid/Whirlpool Icemaker Blues
 in
Refrigerator & Freezer Repair
Hello, The problem is that the timer does not turn. I disconnected it, checked inside for faults, looks OK. Power
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchen Aid/Whirlpool Icemaker Blues
  #1 (permalink)
Old 08-11-2008, 04:08 PM
Varistor Varistor is offline
Junior Member
Varistor is on a distinguished road
Cool Kitchen Aid/Whirlpool Icemaker Blues
Model Number: kscs25fkss02   Brand: Kitchen Aid   Age: 5 - 10 years
Hello, The problem is that the timer does not turn. I disconnected it, checked inside for faults, looks OK. Power wire is good to timer. Correct voltage at black/white(120V). Installed new ice maker kit. Same problem. Then reinstalled old one briefly and the timer/icelever moved for a moment. Some water started to fill, and then suddenly stopped after a trickle of water entered. Figured water is not frozen at valve. Very frustrated. Checked harness. Wiggled wires for possible shorts or bad connections. The new icemaker timer never budged! It's at the 2:00 position. Checked continuity at the harness/fuse---Did not do the t+h test, and what is the brown wire for, I guess the fill valve?? Please help, Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchen aid under cabinet icemaker repairman General Talk 2 07-16-2008 12:05 PM
Whirlpool icemaker BillDuty Refrigerator & Freezer Repair 1 04-03-2008 02:28 PM
Whirlpool Icemaker gwa Refrigerator & Freezer Repair 6 02-26-2008 08:33 PM
Kitchen Aid icemaker issues mcraw Refrigerator & Freezer Repair 2 01-19-2008 11:53 AM
Whirlpool Icemaker parparsons Refrigerator & Freezer Repair 1 07-25-2007 03:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
