I closed the flap on the left side and the light on right stayed red. I also turned it off and on again.:confused:
Originally Posted by: debsoto8190 I closed the flap on the left side and the light on right stayed red. I also turned it off and on again.:confused: Sorry, but I think I'm comming into this about half way through the diagnosis. Did you also hold the door light switch down when you ran the board test? Did the ice production slow down to a stop or did it suddenly occur ? I believe this diagnosis and repair would be better handled by a servicer, as there is a possibility of a malfunctioning ice maker or there is a failure in the communication board(s). I have attached a part number and picture of the control board kit you may need, should you decide to attempt the repair yourself. Part number: AP3137510
