Discuss
Whole fridge and freezer unit pops breaker
 in
Refrigerator & Freezer Repair
Hi, I have a problem with my fridge/freezer unit. I got home artef work today and my fridge light
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whole fridge and freezer unit pops breaker
  #1 (permalink)
Old 09-13-2007, 06:09 PM
manu manu is offline
Junior Member
manu is on a distinguished road
Default Whole fridge and freezer unit pops breaker
Model Number: GLRT214RAW3   Brand: Frigidaire   Age: 1 - 5 years
I got home artef work today and my fridge light was off. Everything in the unit was dead. One of my breaker was also off. I tried to reset it but it did not want to until I disconnected my fridge.
I suspect a short in the electrical system. It must not have started so long ago because the freon tank is still warm.
Where can I start troubleshooting ?
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-13-2007, 08:28 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Plug fridg. in another independent outlet to verify fridg problem. You probably have a shorted compressor. Remove back panel and remove cover on the side of compressor and pry off start relay and overload klixon. Now plug in fridg. It is now probably short free. If not you will need a meter to check things, and consider yourself lucky, your fridg. can be fixed.
__________________
  #3 (permalink)
Old 09-13-2007, 11:22 PM
Junior Member
Default
Thanks for the quick advice. It does look like a short compressor. It will have to be serviced.
Manu
  #4 (permalink)
Old 09-16-2007, 03:45 AM
Senior Expert
APP Volunteer
Default
To save service call, just remove compressor side cover, pry off all components and check each pin for a short to ground.
__________________
  #5 (permalink)
Old 09-16-2007, 08:15 AM
wally38 wally38 is offline
Junior Member
wally38 is on a distinguished road
Default Refriderator ice maker door
The door on my ice maker despenser freezes shut and doesnt allow ice to flow into cup area.
I think the seal has worn out and allows a thaw/freeze cycle. I have located part no. for door assembly(AP206445). Need installation instructions.
Unit is a Kenmore 363.8587781, sn B82020860. Thanks for any help, wally38
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridge and freezer not cooling or freezing gunner_guy26 Refrigerator & Freezer Repair 5 07-23-2008 02:10 PM
freezer freezes but fridge is warm billybob Refrigerator & Freezer Repair 1 09-13-2007 03:50 AM
freezer ok, fridge not cooling 535bimmer Refrigerator & Freezer Repair 0 09-04-2007 04:28 PM
Unit tripping breaker tadtv Refrigerator & Freezer Repair 0 08-13-2007 06:05 PM
Hot Frame between Fridge and Freezer mshilko Refrigerator & Freezer Repair 3 07-20-2007 01:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
