Discuss
Freezer has Ice everywhere. Frige not very cold
 in
Refrigerator & Freezer Repair
Hi, I have a Whirlpool ED25PQXFW02 Side X Side about 10 years old. Recently the fan in the freezer started
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer has Ice everywhere. Frige not very cold
  #1 (permalink)
Old 07-19-2010, 12:27 AM
Junior Member
Gregavi is on a distinguished road
Default Freezer has Ice everywhere. Frige not very cold
Model Number: ED25PQXFW02   Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool ED25PQXFW02 Side X Side about 10 years old. Recently the fan in the freezer started making noise so I emptied it and took the inside back panel off to expose the fan motor. I discovered a lot of ice on the coils. The fan motor was stopped so I took a hair dryer and melted all the ice off the coils, around the fan and push started the fan and it started spinning on its own. Now we are a week later and the fan seems to be spinning still (based on the sound it's making when I open the freezer door) but starting to make that sound again and I now have giant ice cycles in my freezer .The refrigerator section is around 55 degrees F with the dial set to almost the coldest setting. I’m a General Contractor so I’m pretty capable of doing fairly extensive repairs, if I know what the problem is. Any help is greatly appreciated.
Ads By Google
Related Models
Whirlpool ED25PQXYN00
Whirlpool ED25PQXYN01
Whirlpool ED25PQXYW00
Whirlpool ED25PQXYW01
Whirlpool ED25PSQDN00
Whirlpool ED25PSQDN01
Whirlpool ED25PSQDW00
Whirlpool ED25PSQDW01
Whirlpool ED25PSXDN00
Whirlpool ED25PSXDN01
Whirlpool ED25PSXDN02
Whirlpool ED25PSXDW00
Whirlpool ED25PSXDW01
Whirlpool ED25PSXDW02
Whirlpool ED25PSXRWR0
Whirlpool ED25PSXRWR1
Whirlpool ED25PWXAN00
Whirlpool ED25PWXAN01
Whirlpool ED25PWXAN02
Whirlpool ED25PWXAW00
Whirlpool ED25PWXAW01
Whirlpool ED25PWXAW02
Whirlpool ED25PWXBN00
Whirlpool ED25PWXBN01
Whirlpool ED25PWXBW00
Whirlpool ED25PWXBW01
Whirlpool ED25PWXDN00
Whirlpool ED25PWXDN01
Whirlpool ED25PWXDW00
Whirlpool ED25PWXDW01
Whirlpool ED25PWXTF00
Whirlpool ED25PWXTG00
Whirlpool ED25PWXTM00
Whirlpool ED25PWXTN00
Whirlpool ED25PWXTW00
Whirlpool ED25PWXWN10
Whirlpool ED25PWXWW10
Whirlpool ED25PWXXN00
Whirlpool ED25PWXXN01
Whirlpool ED25PWXXW00
Whirlpool ED25PWXXW01
Whirlpool ED25QFXHB00
Whirlpool ED25QFXHB01
Whirlpool ED25QFXHB02
Whirlpool ED25QFXHN00
Whirlpool ED25QFXHN01
Whirlpool ED25QFXHN02
Whirlpool ED25QFXHT00
Whirlpool ED25QFXHT01
Whirlpool ED25QFXHT02
Whirlpool ED25QFXHW00
Whirlpool ED25QFXHW01
Whirlpool ED25QFXHW02
Whirlpool ED25RFXFB00
Whirlpool ED25RFXFB01
Whirlpool ED25RFXFB02
Whirlpool ED25RFXFB03
Whirlpool ED25RFXFN00
Whirlpool ED25RFXFN01
Whirlpool ED25RFXFN02
Whirlpool ED25RFXFN03
Whirlpool ED25RFXFW00
Whirlpool ED25RFXFW01
Whirlpool ED25RFXFW02
Whirlpool ED25RFXFW03
Whirlpool ED25RQXFN00
Whirlpool ED25RQXFN01
Whirlpool ED25RQXFN02
Whirlpool ED25RQXFW00
Whirlpool ED25RQXFW01
Whirlpool ED25RQXFW02
Whirlpool ED25RQXWW00
Whirlpool ED25RQXWW02
Whirlpool ED25RQXXW00
Whirlpool ED25RQXYW00
Whirlpool ED25RQXYW01
Whirlpool ED25RQXYW02
Whirlpool ED25SM1LWR0
Whirlpool ED25SM1LWR1
Whirlpool ED25SMXLWR0
Whirlpool ED25SMXLWR1
Whirlpool ED25SMXLWR2
Whirlpool ED25SMXRWR0
Whirlpool ED25SMXRWR2
Whirlpool ED25TEXHN00
Whirlpool ED25TEXHN01
Whirlpool ED25TEXHN02
Whirlpool ED25TEXHN03
Whirlpool ED25TEXHT02
Whirlpool ED25TEXHT03
Whirlpool ED25TEXHW00
Whirlpool ED25TEXHW01
Whirlpool ED25TEXHW02
Whirlpool ED25TEXHW03
Whirlpool ED25TQXEN00
Whirlpool ED25TQXEN01
Whirlpool ED25TQXEW00
Whirlpool ED25TQXEW01
Whirlpool ED25TQXFN00
Whirlpool ED25TQXFN01
Whirlpool ED25TQXFN02
Whirlpool ED25TQXFN03
Whirlpool ED25TQXFW00
Whirlpool ED25TQXFW01
Whirlpool ED25TQXFW02
Whirlpool ED25TQXFW03
Whirlpool ED25TQXGN00
Whirlpool ED25TQXGW00
Whirlpool ED25TWXDN00
Whirlpool ED25TWXDN01
Whirlpool ED25TWXDW00
Whirlpool ED25TWXDW01
Whirlpool ED25UEXHT00
Whirlpool ED25UEXHT01
Whirlpool ED25UEXHW00
Whirlpool ED25UEXHW01
Whirlpool ED25UQXGN00
Whirlpool ED25UQXGN01
Whirlpool ED25UQXGW00
  #2 (permalink)
Old 07-19-2010, 02:51 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
In the bottom of the control housing locate a large hole. Stick in a flat bladed screwdriver and turn the defrost timer till the compressor stops. If no defrost, you either have a bad defrost heater, or thermostat that clips to the top of the evaporator. If you get defrost, replace the defrost timer AP3110896
__________________
  #3 (permalink)
Old 07-19-2010, 09:27 AM
Junior Member
Default
Thanks Richappy,
So I assume you mean, if, after several hours, all the formed ice in my freezer disappears, then it is the timer. If not (still have ice everywhere) I have a bad defrost heater, or thermostat. Is this correct? I assume the defrost heater is under the unit near the defrost pan? Where is the thermostat located? Thanks again.
  #4 (permalink)
Old 07-19-2010, 03:19 PM
Senior Expert
APP Volunteer
Default
The defrost heater is below the evaporator behind the freezer panel, thermostat clipped to the top of the evaporator.
__________________
  #5 (permalink)
Old 07-19-2010, 09:43 PM
Junior Member
Default
Thanks again. It appears it is the defrost heater or the thermostat since I tried manually turning off the timer and it did nothing. How do I determine which of those it is or should I replace both?
  #6 (permalink)
Old 07-20-2010, 01:45 AM
Senior Expert
APP Volunteer
Default
You can temporarily short the thermostat leads and test, most probably a bad thermostat, I think you have a calrod heater type( steel alloy), that rarely fails.
__________________
  #7 (permalink)
Old 07-20-2010, 09:35 AM
Junior Member
Default
Another theory was given to me by an appliance repair guy:
“Normally I would say that you have a defrost problem, but when you describe it as having ice cycles in your freezer, as opposed to frost, then I have to believe you have a problem with water leaking from your ice maker system, most likely the fill tube that directs the water into the ice maker is somehow allowing water to flow behind the back wall of freezer, and then building up to eventually obstruct the fan blade. Either the fill tube was dislodged, or you have a problem with the valve solenoid not closing completely, thereby dripping up into the fill tube, clogging it with ice, and when the ice maker calls for water, instead of going into the ice maker, the water flows behind the wall.”
What about this possibility? I do have 2" dia. ice cycles forming and it is directly below the ice maker.
Thanks again
  #8 (permalink)
Old 08-08-2010, 11:36 AM
Junior Member
Smile
Update: Replaced fan motor, problem solved.
Thanks for your input.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer / Frige doesn't cold at all! mkkenmore Refrigerator & Freezer Repair 0 02-13-2010 08:52 AM
Amana Frige Not Getting Cold elmer29 Refrigerator & Freezer Repair 1 12-03-2008 04:14 PM
freezer and frige not cold jjsip Refrigerator & Freezer Repair 1 09-17-2008 06:26 PM
Frige not cold enough JON S. Refrigerator & Freezer Repair 5 08-14-2008 08:04 PM
Frige and freezer still not cold enough Treefield Refrigerator & Freezer Repair 0 04-01-2008 07:27 AM
