frezzer compartment not frezzing only cold compressor working also fans working. frezzing at bottom two lines warm at top
my frezzer not frezzing . frost on bottom of evaperator warm at top compressor and fans are working. its only cold in fridgerator
You have refrigeration problems for a pro to look at, probably bad compressor or refigerant leak. Check in the back for a bad condensing fan.
