Discuss
wine cooler problem
 in
Refrigerator & Freezer Repair
I have a wine refridgerator that wont cut on anymore. In the back of it there is a flashing red
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » wine cooler problem
  #1 (permalink)
Old 07-17-2010, 03:38 AM
Junior Member
mhawes47 is on a distinguished road
Default wine cooler problem
Brand: -other-   Age: 1 - 5 years
I have a wine refridgerator that wont cut on anymore. In the back of it there is a flashing red and green light accompanied by a clicking sound. what could be wrong with it, and would it be worth getting fixed? It only cost me 120$ or somthing like that.
  #2 (permalink)
Old 07-17-2010, 06:53 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Pull the cover off the side of the compressor, and pry off the start device and leave on the thin klixon overload attached to the common pin, usually on top. If the device rattles when shaken, or looks burnt, replace it with a GE start device WR07X10055 used for small 1/5 or less hp compressors. If yours is a larger one, use the WR07X10051 device. These devices just plug in and are impossible to plug in wrong.
If you have no condensing fan, then there where only two wires going to the compressor. One wire goes to the klixon, the other wire goes to the top, left of the device, the male spade pin. The other side of the device plugs into the compressor.
Hope this is clear enough.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wine cooler not working bige2323 Refrigerator & Freezer Repair 1 12-18-2009 04:30 AM
Chigo wine cooler Reed General Talk 0 02-14-2009 07:06 AM
wine cooler Ron 988 Refrigerator & Freezer Repair 0 09-18-2007 07:57 PM
