Discuss
Whirlpool refrigerator/freezer makes ice but doesn't dispence
 in
Refrigerator & Freezer Repair
Greetings, My Whirlpool Gold refrigerator/freezer (model GD25DFXFW02) makes ice great, however it does not dispense it out the door. It
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool refrigerator/freezer makes ice but doesn't dispence
  #1 (permalink)
Old 07-16-2010, 07:46 AM
Junior Member
dcolpi is on a distinguished road
Default Whirlpool refrigerator/freezer makes ice but doesn't dispence
Model Number: GD25DFXFW02   Brand: Whirlpool   Age: 5 - 10 years
Greetings,
My Whirlpool Gold refrigerator/freezer (model GD25DFXFW02) makes ice great, however it does not dispense it out the door. It does dispense water fine.
If I take the ice reservoir out of the freezer, depress the inside switch that lets the freezer know that the door is closed, and push the ice dispense lever, the paddle at the back of the freezer does turn. When I replace the ice reservoir and tried again I heard a sound like a motor working too hard (and indeed the dispensing crank doesn't seem to be moving.
So I removed all the ice from the reservoir, washed it out (to remove any frozen parts), let it dry for 4 hours and replaced it (still empty). Here it worked fine (the crank turns now).
So I filled the reservoir with ice again, and it dispensed a small amount of "test ice" fine. Two minutes later, my wife tried to put ice in her glass and nothing happened (needless to say, I got "the look").
Removing the reservoir again and emptying it I saw that there was ice jammed in the output crank, close to the door. I found it to be well lodged (maybe even frozen) in place. I replaced the reservoir and tried to "crush" the ice. No luck. After thawing for a bit I was able to get the ice out. I let dry (in front of a fan this time). Then wiped it out really well to make sure and put the empty reservoir back in the freezer. Works now (dispenser turns). I let it stay in the freezer (empty) to ensure the reservoir itself was cold, and replaced the ice. Works fine again (dispenses ice).
However, two hours later, the paddle at the back of the freezer no longer turns the crank in the ice reservoir, but when the reservoir is removed the paddle turns fine.
Can I assume that the motor has gone bad? If so, is this a replaceable part? Would it come with replacement instructions?
Thanks,
Daniel
Ads By Google
Related Models
Whirlpool GD25DFXFW02 SIDE BY SIDE REFRIGERATOR
Whirlpool GD25DFXFW03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHB00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHS00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHS02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DIXHW02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DQXFB00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DQXFB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DQXFN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DQXFN01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DQXFW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25DQXFW01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25FFCHB00 REFRIGERATOR
Whirlpool GD25FFCHB01 REFRIGERATOR
Whirlpool GD25FFCHT00 REFRIGERATOR
Whirlpool GD25FFCHT01 REFRIGERATOR
Whirlpool GD25FFCHW00 REFRIGERATOR
Whirlpool GD25FFCHW01 REFRIGERATOR
Whirlpool GD25SFCHS10 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25SFCHS11 REFRIGERATOR
Whirlpool GD25SFCHS111 REFRIGERATOR
Whirlpool GD25SFXHS00 SIDE BY SIDE REFRIGERATOR
Whirlpool GD25SFXHS01 SIDE BY SIDE REFRIGERATOR
Whirlpool GD25SFXHS02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25SFXHS03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25SFXHS04 REFRIGERATOR
Whirlpool GD25SFXHS05 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25SHAXLB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25SHAXLQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25SHAXLT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD25SSFCHS10 REFRIGERATOR
Whirlpool GD27DFXFB00 SIDE BY SIDE REFRIGERATOR
Whirlpool GD27DFXFB01 SIDE BY SIDE REFRIGERATOR
Whirlpool GD27DFXFB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DFXFB03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DFXFN00 SIDE BY SIDE REFRIGERATOR
Whirlpool GD27DFXFN01 SIDE BY SIDE REFRIGERATOR
Whirlpool GD27DFXFN02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DFXFN03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DFXFT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DFXFT03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DFXFW00 SIDE BY SIDE REFRIGERATOR
Whirlpool GD27DFXFW01 SIDE BY SIDE REFRIGERATOR
Whirlpool GD27DFXFW02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DFXFW03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHB00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHS00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHS01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHS02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHW01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DIXHW02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DQXFB00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DQXFB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DQXFN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DQXFN01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DQXFW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD27DQXFW01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2LHGXKB00 REFRIGERATOR
Whirlpool GD2LHGXKQ00 REFRIGERATOR
Whirlpool GD2LHGXKT00 REFRIGERATOR
Whirlpool GD2LHGXLB00 REFRIGERATOR
Whirlpool GD2LHGXLB01
Whirlpool GD2LHGXLB03 REFRIGERATOR
Whirlpool GD2LHGXLB04 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2LHGXLQ00 REFRIGERATOR
Whirlpool GD2LHGXLQ01
Whirlpool GD2LHGXLQ03 REFRIGERATOR
Whirlpool GD2LHGXLQ04 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2LHGXLT00 REFRIGERATOR
Whirlpool GD2LHGXLT01
Whirlpool GD2LHGXLT03 REFRIGERATOR
Whirlpool GD2LHGXLT04 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHAXMB00 REFRIGERATOR
Whirlpool GD2NHAXMQ00 REFRIGERATOR
Whirlpool GD2NHAXMT00 REFRIGERATOR
Whirlpool GD2NHGXKB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHGXKB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHGXKQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHGXKQ02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHGXKT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHGXKT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHGXLQ00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2NHGXLT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKB03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKQ02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKQ03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXKT03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXLB00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXLB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXLQ00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXLQ02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXLT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXLT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD2SHAXMB00 REFRIGERATOR
Whirlpool GD2SHAXMQ00 REFRIGERATOR
Whirlpool GD2SHAXMT00 REFRIGERATOR
Whirlpool GD2SHAXNB00 REFRIGERATOR
Whirlpool GD2SHAXNB01 REFRIGERATOR
Whirlpool GD2SHAXNL00 REFRIGERATOR
Whirlpool GD2SHAXNL01 REFRIGERATOR
Whirlpool GD2SHAXNQ00 REFRIGERATOR
Whirlpool GD2SHAXNQ01 REFRIGERATOR
Whirlpool GD2SHAXNS00 REFRIGERATOR
Whirlpool GD2SHAXNS01 REFRIGERATOR
Whirlpool GD2SHAXNT00 REFRIGERATOR
  #2 (permalink)
Old 07-16-2010, 08:50 AM
Junior Member
cao70560 is on a distinguished road
Unhappy Similar Problems but with GS6NVEXS601
I have similar problem with mine. Where do I begin? Makes ice, dispense water, but not ice. I don't hear no sound when I press the paddle. The auger couple doesn't turn with or without the ice bin. Please help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No ice or water dispence, Ice maker makes ice Invader Refrigerator & Freezer Repair 2 11-10-2008 10:32 AM
whirlpool refrigerator side by side icemaker makes little or no ice T-ROY Refrigerator & Freezer Repair 1 11-07-2008 01:37 PM
whirlpool refrigerator-freezer carney Refrigerator & Freezer Repair 0 09-23-2008 07:20 AM
Whirlpool - Freezer very gold, refrigerator is warm italiak Refrigerator & Freezer Repair 14 03-24-2008 03:00 PM
