I have a whirlpool refregerator, the Freezer side coils are freezing up, so the refer gets to warm, so I changed the defrost timer like you said, well it is still freezing up. I have been looking for the defrost heater, but I can't find it anywhere. Also I can't find a tech sheet on my Refrigerator, so I am hoping I wired the new timer right like your kit discribes. I went by Figure 1. I am lost and don't know where to go.:confused:
Your defrost heater and thermostat are behind the freezer panel. Turn the defrost control till the compressor stops, then see if it defrosts, if not, replace the defrost thermostat ( if the heater looks ok); a round thing clipped to the evaporator coil AP4299920
thanks a lot. my refer is fixed and running
