| » ref. light |
Model Number: tfx20jasa wh Brand: GE Age: More than 10 years
Ref. bulb is off. The bulb tests Ok. What do I do next?
Take off the light bulb socket and clean the contacts inside where the bulb screws into, that bottom contact may be corroded. If that does not work, your light switch is most likely bad.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. Last edited by abadfish66 : 08-06-2008 at 10:42 AM. |
I did lightly sand the contacts; that didn't work. How do I replace the switch? Is that something I might do?
Here is the part# Part Details - GE Light switch, part number: WR23X10143
Get a small blade screw driver pop the old one out, and put the new one in, pretty simple. To verify for certain it is the switch, you can remove the switch and put the 2 ends together to see if the light comes on.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
| how to light pilot light | kbrush | Oven Repair (including Ranges and Cooktops) | 0 | 07-05-2008 07:55 PM |
| how to light pilot light | kbrush | Oven Repair (including Ranges and Cooktops) | 0 | 07-05-2008 07:52 PM |
| How do I light dryer pilot light? | Arleen | Dryer Repair | 1 | 03-20-2008 07:11 PM |
| cna't light pliot light | Rosanne | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2007 10:27 PM |
