Discuss
ref. light
 in
Refrigerator & Freezer Repair
Ref. bulb is off. The bulb tests Ok. What do I do next?
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ref. light
  #1 (permalink)
Old 08-06-2008, 09:37 AM
ted siegan ted siegan is offline
Junior Member
ted siegan is on a distinguished road
Default ref. light
Model Number: tfx20jasa wh   Brand: GE   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-06-2008, 10:23 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Take off the light bulb socket and clean the contacts inside where the bulb screws into, that bottom contact may be corroded. If that does not work, your light switch is most likely bad.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-06-2008, 02:51 PM
Junior Member
Default
Quote:
I did lightly sand the contacts; that didn't work. How do I replace the switch? Is that something I might do?
  #4 (permalink)
Old 08-06-2008, 03:16 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Here is the part# Part Details - GE Light switch, part number: WR23X10143
Get a small blade screw driver pop the old one out, and put the new one in, pretty simple. To verify for certain it is the switch, you can remove the switch and put the 2 ends together to see if the light comes on.
__________________
  #5 (permalink)
Old 08-12-2008, 01:15 PM
Junior Member
Default
That little rectangular housing for the switch doesn't pop right off with a small screwdriver. Is it attached to some wires or something behind the frame? Or is it just really stubborn?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how to light pilot light kbrush Oven Repair (including Ranges and Cooktops) 0 07-05-2008 07:55 PM
how to light pilot light kbrush Oven Repair (including Ranges and Cooktops) 0 07-05-2008 07:52 PM
How do I light dryer pilot light? Arleen Dryer Repair 1 03-20-2008 07:11 PM
cna't light pliot light Rosanne Oven Repair (including Ranges and Cooktops) 0 11-21-2007 10:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
