I have a GE tfx27prxd aa refrigerator and the ice maker control switch for water,crushed ice, ice cube is on the fritz. I have located the part in your list but can't see how to replace with just the simple diagram. Do I have remove the inside of the door or is there a trick to replacing from the outside of the door? thanks
