The fridge is giving out a bad odour. I think milk that had spilt into the bottom of fridge also drained into the vents at the bottom. Don't know where it goes but, at back of fridge there seems to be a hole that possibly acts as a drain. Should I run water to try and flush out or how do I under or behind these vents get to this part? Thanks for your help. :confused:
