Discuss
Refrig not cooling.
 in
Refrigerator & Freezer Repair
Amana model # ARS9265BB. Worked great since 2005, then stopped cooling this past weekend for 2 days and then started
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrig not cooling.
  #1 (permalink)
Old 07-09-2010, 04:29 PM
Junior Member
Bob Hunt is on a distinguished road
Default Refrig not cooling.
Model Number: ARS9265BB   Brand: Amana   Age: 1 - 5 years
Worked great since 2005, then stopped cooling this past weekend for 2 days and then started back cooling. Could hear circulation fan running in freezer side, lights worked, but no cooling.
Ads By Google
Related Models
Amana ARS9265BB  Ref - SXS/I&W
Amana ARS9265BC  Ref - SXS/I&W
Amana ARS9265BW  Ref - SXS/I&W
Amana ARS9266BS  Ref - SXS/I&W
Amana ARS9268BB  Ref - SXS/I&W
Amana ARS9268BC  Ref - SXS/I&W
Amana ARS9268BW  Ref - SXS/I&W
Amana ARS9269BS  Ref - SXS/I&W
Amana ARSE664BB Ref - SXS/I&W
Amana ARSE664BC Ref - SXS/I&W
Amana ARSE664BS Ref - SXS/I&W
Amana ARSE664BW Ref - SXS/I&W
Amana ARSE665BB  Ref - SXS/I&W
Amana ARSE665BC  Ref - SXS/I&W
Amana ARSE665BS  Ref - SXS/I&W
Amana ARSE665BW  Ref - SXS/I&W
Amana ARSE667BB Ref - SXS/I&W
Amana ARSE667BC Ref - SXS/I&W
Amana ARSE667BS Ref - SXS/I&W
Amana ARSE667BW Ref - SXS/I&W
Amana ARSE66MBB Ref - SXS/I&W
Amana ARSE66MBC Ref - SXS/I&W
Amana ARSE66MBW Ref - SXS/I&W
Amana ARSE66ZBB  Ref - SXS/I&W
Amana ARSE66ZBC  Ref - SXS/I&W
Amana ARSE66ZBS  Ref - SXS/I&W
Amana ARSE66ZBW  Ref - SXS/I&W
Amana ARSE67RBB  Ref - SXS/I&W
Amana ARSE67RBC  Ref - SXS/I&W
Amana ARSE67RBS  Ref - SXS/I&W
Amana ARSE67RBW  Ref - SXS/I&W
Amana ART1805BC Ref - Top Mount
Amana ART1805BW Ref - Top Mount
Amana ART2105BB Ref - Top Mount
Amana ART2105BC Ref - Top Mount
Amana ART2105BW Ref - Top Mount
Amana ART2107BB Ref - Top Mount
Amana ART2107BC Ref - Top Mount
Amana ART2107BS Ref - Top Mount
Amana ART2107BW Ref - Top Mount
Amana ART2127AB Ref - Top Mount
Amana ART2127AC Ref - Top Mount
Amana ART2127AS Ref - Top Mount
Amana ART2127AW Ref - Top Mount
Amana ART2129ABR Ref - Top Mount
Amana ART2129ACR Ref - Top Mount
Amana ART2129ASR Ref - Top Mount
Amana ART2129AWR Ref - Top Mount
Amana ART2527AB Ref - Top Mount
Amana ART2527AC Ref - Top Mount
Amana ART2527AW Ref - Top Mount
Amana ART5400L Range - Std Mwave Ele
Amana ART5400W Range - Std Mwave Ele
Amana ART6000L Range - S/c S/i Ddraft Gas
Amana ART6000W Range - S/c S/i Ddraft Gas
Amana ART6001L Range - S/c S/i Ddraft Gas
Amana ART6001W Range - S/c S/i Ddraft Gas
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C Range - S/c S/i Ddraft Gas
Amana ART6021L Range - S/c S/i Ddraft Gas
Amana ART6021W Range - S/c S/i Ddraft Gas
Amana ART6100E Range - S/c S/i Ddraft Gas
Amana ART6100LL Range - S/c S/i Ddraft Gas
Amana ART6100WW Range - S/c S/i Ddraft Gas
Amana ART6110E Range - S/c S/i Ddraft Ele
Amana ART6110LL Range - S/c S/i Ddraft Ele
Amana ART6110W Range - S/c S/i Ddraft Ele
Amana ART6110WW Range - S/c S/i Ddraft Ele
Amana ART6112LL Range - S/c S/i Ddraft Ele
  #2 (permalink)
Old 07-10-2010, 02:30 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
What was running/not running when it failed?
__________________
  #3 (permalink)
Old 07-10-2010, 05:47 AM
Junior Member
Default
It just stopped cooling. Could hear the fan running on the freezer side when I opened the freezer door. Started back cooling about 36 to 48 hours later. Any ideas?
  #4 (permalink)
Old 07-10-2010, 06:20 AM
Senior Expert
APP Volunteer
Default
Your evaporator fan and compressor are wired in parallell through splices. I would check all connectors in the control panel for a burnt, loose splice or wire. You can remove all connectors and spay them with a non-residue contact cleaner, then plug them in.
The other area would be the compressor terminals, look for a burnt/loose wire.
__________________
  #5 (permalink)
Old 07-10-2010, 05:29 PM
Junior Member
Default
Stopped cooling again last night. Will check and clean connections and look for loose or burnt wires. Would a faulty capacitor cause this problem.
Thank you.
  #6 (permalink)
Old 07-11-2010, 01:42 AM
Senior Expert
APP Volunteer
Default
If the compressor is cold when it fails, that would rule out a faulty capacitor.
__________________
  #7 (permalink)
Old 07-13-2010, 02:49 PM
Junior Member
Default
The overload relay was faulty. When I removed it, I could hear it rattling.
Installed a new one a couple of hours ago, and it seems to be functioning normally.
Thanks for your replies.
Bob
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrig and freezer not cooling donerite44 Refrigerator & Freezer Repair 1 10-10-2009 03:02 AM
refrig not cooling properly mhall Refrigerator & Freezer Repair 0 08-08-2009 09:46 AM
Refrig / freezer not cooling DaveO Refrigerator & Freezer Repair 1 07-03-2009 06:36 AM
refrig portion not cooling ANiforos Refrigerator & Freezer Repair 7 12-12-2008 06:27 PM
whirlpool s/s refrig. not cooling wrc1 Refrigerator & Freezer Repair 1 11-16-2008 09:51 AM
