Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   dual water valve installation (http://forum.appliancepartspros.com/refrigerator-freezer-repair/105373-dual-water-valve-installation.html)
nancytp2000 07-09-2010 12:27 PM
I bought the part from you... came with no instructions. back is off fridge, how does valve get disconnected. WHAT GOOD IS A PART IF YOU DON'T SEND A SCHEMATIC OR INSTRUCTIONS WITH IT?
Gene 07-09-2010 05:20 PM
Quote:
Originally Posted by nancytp2000 (Post 238703)
...WHAT GOOD IS A PART IF YOU DON'T SEND A SCHEMATIC OR INSTRUCTIONS WITH IT?...
All the installation instructions are made by the manufacturer and only the manufacturer decided to include or not such instructions with a part.
Shut off the water to the refrigerator. Disconnect the incoming water line from the water inlet valve. Remove the plastic tubes from the water inlet valve by pushing in the center collar while pulling out the tube.
Install the new water inlet valve in the reversed order.
Here are the breakdown diagrams and Replacement parts for MAYTAG MSD2351HEB Ref - SXS/I&W | AppliancePartsPros.com
nancytp2000 07-09-2010 05:54 PM
Thanks for your help, Gene.
The tubes are easy to remove, once you know the trick.
Nancy
Gene 07-09-2010 07:22 PM
You are welcome Nancy. I'm glad you were able to fix it.
