The system was working fine. I turned off the unit when I left for a 3 week trip. I came back, turned it on, and everything seems to work except the recirculating pump is not coming on. It is 4 years old using water with a lot of scale. I had to replace the inlet pump last year.
Do I just need to replace the pump? Any ideas?
Thanks.
