Discuss
dryer Whirlpool not heating
 in
Refrigerator & Freezer Repair
The dryer starts but does not heat. I tried all the different cycles and it won't heat. Also, when it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » dryer Whirlpool not heating
  #1 (permalink)
Old 07-06-2010, 06:13 PM
Junior Member
rafaelgm is on a distinguished road
Default dryer Whirlpool not heating
Model Number: LER5620KQ1   Brand: Whirlpool   Age: 5 - 10 years
Also, when it starts, it keeps going and does not stop.
Suggestions?
Thanks!
Ads By Google
Related Models
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
  #2 (permalink)
Old 07-07-2010, 06:04 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LER5620KQ1 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/w...%208528187.pdf
Sounds like you are not getting 240 volts to the unit.
The reason I say this is that on this unit in timed dry the timer runs off the 240 volts directly (TM/WB timer contacts closed). You said you tried all modes and it will not advance or heat and both of theses require the 240 volts.
Try flipping the breaker off/on slowly a couple times, sonetimes you can loose half the line without actually tripping the breaker.
__________________
  #3 (permalink)
Old 07-07-2010, 06:11 AM
Junior Member
Default
Thanks denman.
I've tried switching the breaker on/off but it didn't work.
Do you think I should replace the timer?
  #4 (permalink)
Old 07-07-2010, 04:35 PM
Senior Expert
APP Volunteer
Default
No, I would invest in a meter or get a friend to check it for you.
Just putting parts into a unit without some further troubleshooting will just cost you money.
Also on the timer the heater contacts in the timer and the timer motor would have to have gone bad at the same time and this is unlikely.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Once you confirm that the unit is getting the correct power using AC volts scale, you can use the meter to find the faulty part using ohms (unit unplugged) which is much safer that trying to locate a bad part with power on.
__________________
  #5 (permalink)
Old 07-07-2010, 04:51 PM
Junior Member
Default
you are absolutely right!
I'm only getting 120V.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool gas dryer not heating up sas5417 Dryer Repair 2 04-12-2011 06:53 AM
whirlpool dryer not heating skats Dryer Repair 3 02-17-2011 04:22 PM
Whirlpool dryer not heating davelions Dryer Repair 0 01-05-2010 02:31 PM
Whirlpool Dryer not heating mangboy Dryer Repair 1 08-17-2009 04:53 AM
Whirlpool dryer not heating distressed Dryer Repair 1 12-08-2008 11:26 AM
