| » Freezer ice build up |
Model Number: GSH22JSTASS Brand: GE Age: Less than 1 year
The frig is only 13 months old and GE will not honor the warranty. I am seeing ice biuld up in the freezer. I unplugged and defrosted for 24 hours. It worked fine for about a month, but I just noticed that is building up ice again. Any suggestions?
Is your Ice build up on the freezer walls or in the ice dispenser? My Crosley side by side's ice dispenser freezes solid with frost in the summer months. I have to open the door to get ice. I can still get water in the door--just not ice.
The heater is glass and does tend to crack and die. Remove the access panel and check the glass defrost heater for continuity.
If this Defrost thermostat is bad then the heater won't work.defrost heater thermostat.jpgTo test this part you must place it into a freezer for 2 hours or more, While it is at room temperature it will not have an ohms reading. When it is frozen it closes and has an ohm's reading.
I was checking for blockage on the air return and found the fan blower to be very hard to turn by hand. If the fan does not turn will this keep the fridge from cooling? The fan appears to have corrosion and rust around the transformer motor.
| Display Modes | |
| ICE Build up in freezer | monahanjp | Refrigerator & Freezer Repair | 0 | 02-01-2010 09:02 AM |
| ice build-up in freezer | CHROMEDOME41@HOTMAIL.COM | Refrigerator & Freezer Repair | 0 | 02-10-2009 08:09 PM |
| Frost Build-Up in freezer (refrig & freezer not as Cold as usual) | boots1 | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2009 03:08 AM |
| Freezer cold, evaporator fan not working, frost build up in freezer | heretolearn2 | Refrigerator & Freezer Repair | 3 | 05-28-2008 02:45 PM |
| Freezer with ice build | Bob M | Refrigerator & Freezer Repair | 2 | 03-07-2008 02:02 PM |
