my ice maker drips some water into the icepan making the ice to stick, is the water valve the problem?
Is the ice maker overfilled with water? If yes, then the problem is a bad water inlet valve. If no, then the ice maker itself is leaking and has to be replaced. - The water inlet valve Part number: AP4303451
