I replaced the evaporator fan in the freezer and it works good. Now the fridge is only cooling to 45 degrees. What could be wrong? Before replacing the fan in freezer, the fridge was cooling around 38, and the temp control was not turn down all the way.
Measure the freezer temperature and post.
Originally Posted by: richappy Measure the freezer temperature and post. The freezer is at 8 degrees
Freezer seems ok, why did you replace the fan motor? Check that the fan is blowing air and turning in the right direction. Also, check for a ice clog in the lower return vent.
Amana fridge warm, freezer cold
(Refrigerator & Freezer Repair)
by agdodge4x4
12/25/2023 6:22:47 PM(UTC)
Fridge warm, freezer cold, evaporator covered in ice
by adrianvm
10/14/2023 10:45:13 AM(UTC)
GE GTS18GSSHMRSS Fridge Warm, Freezer Cold
by Pete Pliers
4/19/2023 4:41:06 PM(UTC)
Whirlpool wrx735sdbe00 - Fridge warm no ice
by old_school33
6/10/2022 2:29:09 PM(UTC)
Fridge warm, freezer is fine - Can it be the dampers if they pass the diagnostics?
by ocjk
6/23/2021 7:39:39 PM(UTC)
Amana ABB2224WEB2 freezer and fridge warm
by aefbae
12/30/2020 10:38:33 AM(UTC)
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer
by jhmon
5/29/2020 12:20:04 AM(UTC)
Freezer works, Fridge Warm
by cpb521
12/18/2019 6:11:02 AM(UTC)
Freezer Stopped Working, Fridge Warm As Well
by Desi4881
5/26/2019 1:09:05 PM(UTC)
fridge warm, replaced locked down evaporator fan
by dtmeyer
1/6/2018 9:23:36 PM(UTC)
Whirlpool Defrost not working and freezer and fridge warming up
by kimberdesi
9/13/2017 12:37:45 PM(UTC)
Maytag WFF2557HEB French Door, Freezer and Fridge Warm
by Agent0071
10/18/2016 7:13:59 AM(UTC)
Fridge warm, ice only between sides
by Itallbreaks
7/2/2016 7:29:32 PM(UTC)
Freezer cold, fridge warm Whirlpool
by Debma
1/25/2016 11:09:49 PM(UTC)
Samsung RS261MDWP fridge warm/freezer cold
by Rchcraft9
7/31/2015 6:08:29 PM(UTC)
