Not sure of the age. Daughters washer came with the house she just purchased. It won't empty at the end of any wash cycle. Timer does not advance either. Lowering the drain hose to the floor level and water does drain by gravity. Seems the drain pump isn't starting. Anyone have a suggestion, or better a manual reference? :confused: I'll be going there Friday and any information will be appreciated. Thanks
