| » broken water line inside freezer door |
Model Number: ed5phaxsboo Brand: Whirlpool Age: 1 - 5 years
i have a whirlpool side by side with a broken water line inside freezer door. can i replace it and how? model is ed5phaxsboo
Yes, it can be done. You have to order new fitting kit. The instructions are attached to the reply.
- The fitting Part number: AP3179954 Here are the breakdown diagrams and Dispenser front parts replacement parts for WHIRLPOOL ED5PHAXSB00 Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Did you read the previous post?
The instructions are attached to it and you can use the same part number. Gene.
__________________
Quote:
What if I have a GE side by side Gss25sgmdbs? The line is cut at the bottom hinge, so I need to replace the line. Is it the basic same assembly or is something else needed? |
Quote:
- The tube assembly Part number: WR17X11116 Here are the breakdown diagrams and Replacement parts for General Electric GSS25SGMDBS Refrigerator | AppliancePartsPros.com Gene. P.S. It is possible that you will have to remove the inner door panel to do this job.
__________________
Gene: Thanks, that was the part I thought I needed, but is there anywhere where I can determine if door panel needs to be removed. I thought I would be able to take apart the ice maker panel, and pull the tube out and rethread. The diagram from GE does not indicate how the line is threaded through.
Any direction would be appreciated. |
Quote:
__________________
Gene:
I got the part, but I am not sure how this escutcheon or trim plate is removed. I do not want to break it, and am not positive on how to remove. Any help to get it off will be appreciated. Some forums discuss pushing and removing by the tabs. Not sure how it works. |
I went to Ace and bought 6 inches of rubber water hose, $1.89 that would fit both side and used hose clamps. Cut out hole and attach hose and use the hose clamps. Mine has been working ever since, for years, mine is a GE pss29ngmbcc. The water line cracked in two places where the line bent to sharp when it was only 2 years old. GE wanted $275 to replace the line. GE should of just used good plastic hose intead of being CHEEP.
| Display Modes | |
| Broken Water line @ base freezer door | adamshad | Refrigerator & Freezer Repair | 0 | 05-18-2010 12:11 AM |
| water leak inside freezer door | ellioje1 | Refrigerator & Freezer Repair | 0 | 02-18-2010 07:06 PM |
| how to replace a water line in freezer door? | keltserg | Refrigerator & Freezer Repair | 0 | 10-26-2009 07:27 PM |
| How Do U Replace Line Inside Freezer Door That Supplies Drinking Water To Outside Of | fscjr | Refrigerator & Freezer Repair | 0 | 03-14-2009 02:50 PM |
| frozen line inside door | ge guy | Refrigerator & Freezer Repair | 1 | 01-02-2009 07:21 PM |
