Discuss
Frezzer making a whistling sound and won't make ice
 in
Refrigerator & Freezer Repair
My freezer is only 2 years old and always worked fine, but recently it has been making a whistling sound
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frezzer making a whistling sound and won't make ice
  #1 (permalink)
Old 09-12-2007, 02:10 PM
nickysduck2 nickysduck2 is offline
Junior Member
nickysduck2 is on a distinguished road
Default Frezzer making a whistling sound and won't make ice
Model Number: HSS25GFPJ   Brand: Hotpoint   Age: 1 - 5 years
My freezer is only 2 years old and always worked fine, but recently it has been making a whistling sound off and on and sounds like the motor kicks off and on a lot.It's also stopped making ice.I lost my owners manual so i can't troubleshoot the problem. The sound is annoying.It is still freezing fine and this seems to be the only problem.Whays should I do?
Nickysduck2
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-12-2007, 04:20 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Measure the temperature inm the freezer, must be below 15 degrees for icemaker. Turn cold control to higher number and re-check. Also check condensing coils for clog.
You have the infamous "motherboard" in the back of the fridge. It sends different frequencies to the evaporator motor as a function of cooling demand.
Call GE, they where replacing them free, but maybe no more!!
If not, your recourse is to change it. If you have a meter and a little knowledge I can send you more info.If you do.go to www.*************.com/forum1/3075.html At this site you will get info on where to test the thermistors and other things.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Making Too Much Ice - Now Making No Ice aolson51 Refrigerator & Freezer Repair 2 09-19-2007 02:59 PM
freezer not making ice suresh Refrigerator & Freezer Repair 2 09-10-2007 06:32 AM
icemaker will not make ice RKCarpet Refrigerator & Freezer Repair 2 08-03-2007 07:30 PM
Ice maker not making ice Bryne Grammer Refrigerator & Freezer Repair 1 08-02-2007 06:36 PM
Annoying sound Russ Law Refrigerator & Freezer Repair 1 07-23-2007 11:10 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
