| » Frigidaire frig unit only not cooling freezer separate unit |
Model Number: PLRU1777DSO Brand: Frigidaire Age: 1 - 5 years
These are side by side units, frig and freeze separate units. I have already cranked up the setting to coldest but it's still not cold. I did allow enough time for to adjust....weeks. What parts do you recommend replacing?
Remove the rear cover and clean the condenser. Make sure the fan motor next to the compressor works properly.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE PLRU1777DS0 Frigidaire/refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I have exactly the same problem with my Frigidaire PLRU1777DSO and would be intererested if Corrina0301 has solved the problem with hers.
I have totally cleaned mine (back and bottom and have checked to ensure the cooling coil is not icing up (its not). Fans run fine, but just doesn't get sufficiently cold. I have ordered the temperature controller but have not received it yet. If that doesn't work, I assume I will need to get a professional to recharge the refrigerant, unless there is some other simple parts change out that might be worth trying......? |
| Display Modes | |
| Frigidaire heating/cooling window unit | miketieman | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 03-18-2012 02:47 PM |
| help! unit not cooling | hmi | Refrigerator & Freezer Repair | 2 | 12-03-2009 04:15 AM |
| Entire unit not cooling | Espritman | Refrigerator & Freezer Repair | 0 | 11-04-2009 05:56 AM |
| fridge/freezer motor running, unit not cooling | mountain man | Refrigerator & Freezer Repair | 1 | 04-28-2009 09:26 AM |
| Frigidaire unit won't heat | deedeeg1049 | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 11-21-2008 01:22 PM |
