While troubleshooting the fan and testing the wires in the harness attached to the fan, the wires separated from the harness clip. On the fan side, there is white, red, yellow and blue. On the fridge side there is white, red and pink. Is the yellow on the fan side supposed to be connected to the pink on the fridge side?
As an aside, I am replacing the control board, as there is relay clicking which happens intermittently, and the fan does not operate.
