| » Water Dispenser Not Working |
Model Number: GSS25WGPDBB Brand: GE Age: 5 - 10 years
Hello,
I am not getting any water out of my dispenser. The following is what I have attempted to do already. Your help will be greatly appreciated. I have purchased from you and installed the following parts: 1). WR62X10055 - SOLENOID ASM 2). WR57X10032 - WATER VALVE 3). WR49X10233 - SPRING TORSION FIT 4). WR17X11267 - FUNNEL ICE DISPLAY 5). WR17X11170 - HOUSING SHIELD DISP 6). WR17X10706 - CRANK DOOR RECESS 7). WR23X10224 - SWITCH 8). WR02X10585 - SPRING RECESS DOOR Additionally I have validated the water source to the unit is good. I have replaced the water filter and reset it. I held the water dispenser down several times for more than 3 minutes with no results. (HELP) Ads By Google Related Models |
At the bottom if the door there is a connector take that connector apart, close the door and try to dispense water and if you get water to come out the hose then the line is frozen in the door.
If this is the case open the door and press the door switch and repeatedly press the switch to dispense water until water comes out the door. GE makes a heater that will stop this from happening again. Also if that is not the problem see if the lights dim when you try to dispense water and if so the main board is the prolblem. Try this page GE Refrigerators Repair Guide |
| Display Modes | |
| Ice Maker not working, water dispenser is working fine | Monique | Refrigerator & Freezer Repair | 43 | 08-21-2012 09:18 PM |
| Ice dispenser not working but water dispenser is???? | steinflg | Refrigerator & Freezer Repair | 1 | 07-31-2011 11:10 AM |
| water dispenser not working | tarisbulba | Refrigerator & Freezer Repair | 0 | 05-20-2010 03:58 AM |
| Ice dispenser working, Water dispenser not working | jljw11 | Refrigerator & Freezer Repair | 0 | 01-10-2009 01:07 PM |
| ice dispenser working...water dispenser not | rishuk | Refrigerator & Freezer Repair | 0 | 09-25-2007 03:03 PM |
