Discuss
Water leak in ice maker
 in
Refrigerator & Freezer Repair
Hi,I owned a MZD2766GEW forapprox. 5 years and just hooked up the ice maker. Tested the connections by running
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water leak in ice maker
  #1 (permalink)
Old 09-12-2007, 01:16 PM
Brown4repair Brown4repair is offline
Junior Member
Brown4repair is on a distinguished road
Question Water leak in ice maker
Model Number: MZD2766GEW   Brand: Maytag   Age: 1 - 5 years
Hi,I owned a MZD2766GEW forapprox. 5 years and just hooked up the ice maker. Tested the connections by running water through the dispenser for 10 min+.No leaks,but a lot of noise.When I turned on the tce maker switch(block),ice formed,but the unit leaked under the icemaker compartment after returning back to water dispenser.What happened and how to fix? Thanks for your help.
brown4repair
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-13-2007, 03:41 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Huh, are you saying the icemaker filled with water when you pushed the water dispenser switch!!??
__________________
  #3 (permalink)
Old 12-23-2007, 04:27 PM
rstbr493 rstbr493 is offline
Junior Member
rstbr493 is on a distinguished road
Default
i have the same one, also had the same problem. found that it came to much humidity in the kitchen, also the rotator assembly of the ice maker had frozen particles that would block the rotator from a full spin. making the arm think it was done, to restart. restart means letting water back in the filling tray for ice to begin to freeze. i never could get the problem corrected so i unhooked the water line.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker not getting water DBBromberg Refrigerator & Freezer Repair 3 09-24-2007 09:30 AM
Water Dispenser/Ice Maker not working Michael_Timberblind Refrigerator & Freezer Repair 3 09-02-2007 07:16 PM
water leak from Ice dispenser tsherman Refrigerator & Freezer Repair 0 09-02-2007 02:31 PM
Ice Maker dispensing ice and water karen54 Refrigerator & Freezer Repair 0 08-20-2007 07:42 PM
Ice maker not getting water. brandon58 Refrigerator & Freezer Repair 1 07-30-2007 03:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
