Draft beer dispenser is running too hot what should i do?
A make and model may help others help you. Often though technical data is not available for these units. Also you did not say what is too warm. If it is a unit that uses a compressor check that the compressor is running. If no then it may be a thermostat problem. If yes and the unit is frost free, it may be a defrost problem or a sealed system re: low freon etc. Here are a couple good sites on fridge repair. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com http://www.applianceaid.com/frig.htmlIf it uses a peltier cell then it could also be a thermostat problem or the fan is not working. |
THIS FORUM IS DEAD!!!!!!! |
