Discuss
Refrigerator (icemaker)
 in
Refrigerator & Freezer Repair
No water is running into the icemaker. Water line to icemaker on back of frig is OK. Is there any
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator (icemaker)
  #1 (permalink)
Old 07-29-2008, 03:31 PM
lillypad lillypad is offline
Junior Member
lillypad is on a distinguished road
Default Refrigerator (icemaker)
Brand: Whirlpool   Age: 5 - 10 years
No water is running into the icemaker. Water line to icemaker on back of frig is OK. Is there any way to check the water valve to see if it is working properly? Any other ideas as to what may be wrong?
  #2 (permalink)
Old 07-30-2008, 10:26 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you have a water dispenser on the freezer door, just go to the back of fridg, remove panel and swap the two connectors going to the water solenoid. Next, press the water dispenser and see if water goes into the ice maker, if so, you probably have a bad ice maker or water valve.
To confirm, stick 115 volts to the terminals of the water solenoid that feeds the smaller plastic line. If no water=bad water solenoid, or frozen fill tube in the freezer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help with icemaker detrob340 Refrigerator & Freezer Repair 0 07-07-2008 06:18 PM
KitchenAid Refrigerator/Icemaker not making ice smking Refrigerator & Freezer Repair 4 02-07-2008 07:39 PM
Icemaker Elton Gillam Refrigerator & Freezer Repair 3 01-20-2008 03:14 PM
Refrigerator icemaker Blackjack Refrigerator & Freezer Repair 3 11-19-2007 08:55 PM
which ge icemaker kenneth2 Refrigerator & Freezer Repair 0 10-12-2007 06:17 AM
