my frig is leaking from the freezer side i think its coming down from the lowest vent and pooling @bottom of freezer floor somtimes it stay frozen on floor and somtimes it leakes between door onto floor:mad:
Here are your parts Replacement parts for MAYTAG MZD2766GEQ Ref - SXS/I&W | AppliancePartsPros.comHere is a service manual http://www.servicematters.com/maytag_library/docs/16010154.pdfCannot be of much help without actually being there. You just have to trace the leak back to find it's source. There is a possibility that the drain hose at the bott0om of the freezer is plugged and the water is from the defrost cycle. Check that is is clear and not plugged at the drip tray with lint etc. Usually they can be cleared with compressed air or a turkey baster filled with warm water. If it is this, it is a good idea to flush it out wioth a 10 % bleach solution this kills any crud growing in it. Just be careful to not overflow the drip teray. |
THIS FORUM IS DEAD!!!!!!! |
