Discuss
Refrigerator troubles
 in
Refrigerator & Freezer Repair
Maytag side by side refrigerator. Freezer works but refrigerator side wasn't cooling. After removal of freezer back panel I discovered
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator troubles
  #1 (permalink)
Old 07-29-2008, 10:17 AM
Junior Member
rosto is on a distinguished road
Default Refrigerator troubles
Model Number: RSW22E0DAE   Brand: Maytag   Age: More than 10 years
Maytag side by side refrigerator. Freezer works but refrigerator side wasn't cooling. After removal of freezer back panel I discovered the fins were iced over. Moved fridge to garage and thawed out and cleaned everything. Started the fridge up again and both freezer & fridge appear to be cooling. However, when I open up the freezer door and then close the door it creates a vacumm in the refrigerator side. It sounds as if the door on the refrigerator side is being sucked in for several seconds and then a gurgling sound happens in the drain tube. I did clean out the drain tube before turning the fridge back on. Any suggestions?
Ads By Google
Related Models
Maytag RSW22E0DAE Ref - SXS/I&W
Maytag RSW22E0DAM Ref - SXS/I&W
Maytag RSW2400AAE Ref - SXS/I&W
Maytag RSW2400AAL Ref - SXS/I&W
Maytag RSW2400AAW Ref - SXS/I&W
International RSW2400AGE Ref - SXS/I&W
Maytag RSW2400BAE Ref - SXS/I&W
Maytag RSW2400CAB Ref - SXS/I&W
Maytag RSW2400CAE Ref - SXS/I&W
Maytag RSW2400CAL Ref - SXS/I&W
Maytag RSW2400CAW Ref - SXS/I&W
International RSW2400CKE Ref - SXS/I&W
International RSW2400CKL Ref - SXS/I&W
Maytag RSW2400EAB Ref - SXS/I&W
Maytag RSW2400EAE Ref - SXS/I&W
Maytag RSW2400EAM Ref - SXS/I&W
Maytag RSW2400EAW Ref - SXS/I&W
International RSW2400EKE Ref - SXS/I&W
International RSW2400EKM Ref - SXS/I&W
Maytag RSW24A Ref - SXS/I&W
Maytag RSW24B Ref - SXS/I&W
Maytag RSW24E0CAB Ref - SXS/I&W
Maytag RSW24E0CAE Ref - SXS/I&W
Maytag RSW24E0CAL Ref - SXS/I&W
Maytag RSW24E0CAW Ref - SXS/I&W
Maytag RSW24E0DAB Ref - SXS/I&W
Maytag RSW24E0DAE Ref - SXS/I&W
Maytag RSW24E0DAM Ref - SXS/I&W
International RSW24E0ZAE Ref - SXS/I&W
International RSW24E0ZAL Ref - SXS/I&W
International RSW24E0ZAM Ref - SXS/I&W
Maytag RSW2700DAB Ref - SXS/I&W
Maytag RSW2700DAE Ref - SXS/I&W
Maytag RSW2700DAM Ref - SXS/I&W
Maytag RSW2700EAB Ref - SXS/I&W
Maytag RSW2700EAE Ref - SXS/I&W
Maytag RSW2700EAM Ref - SXS/I&W
International RSW2700EKE Ref - SXS/I&W
International RSW2700EKM Ref - SXS/I&W
Amana RSW2TK24 Ele Cartridge
Amana RSW458P Mwave - Cntrtp / Stand Alone
Amana RSW459P Mwave - Cntrtp / Stand Alone
Amana RSW659P Mwave - Cntrtp / Stand Alone
Amana RSW669T Mwave - Cntrtp / Stand Alone
Admiral RSWA228AAE Ref - SXS/I&W
Admiral RSWA228AAM Ref - SXS/I&W
Admiral RSWA248AAE Ref - SXS/I&W
Admiral RSWA248AAM Ref - SXS/I&W
Admiral RSWA278AAE Ref - SXS/I&W
Admiral RSWA278AAM Ref - SXS/I&W
Maytag RT11 Ref - Single Door
Frigidaire RT114GCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114GCD2 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114GCD3 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114GCD5 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114GCH1 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT114GCH2 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT114GCH3 Wwh(v7) / Top Mount Refrigerator
Frigidaire RT114GCH5 Wwh(v8) / Top Mount Refrigerator
Frigidaire RT114GCV1 Wwh(v9) / Top Mount Refrigerator
Frigidaire RT114GCV2 Wwh(v10) / Top Mount Refrigerator
Frigidaire RT114GCV3 Wwh(v11) / Top Mount Refrigerator
Frigidaire RT114GCV5 Wwh(v12) / Top Mount Refrigerator
Frigidaire RT114GCW1 Wwh(v13) / Top Mount Refrigerator
Frigidaire RT114GCW2 Wwh(v14) / Top Mount Refrigerator
Frigidaire RT114GCW3 Wwh(v15) / Top Mount Refrigerator
Frigidaire RT114GCW5 Wwh(v16) / Top Mount Refrigerator
Frigidaire RT114GLD5 Wwh(v17) / Top Mount Refrigerator
Frigidaire RT114GLH5 Wwh(v18) / Top Mount Refrigerator
Frigidaire RT114GLV5 Wwh(v19) / Top Mount Refrigerator
Frigidaire RT114GLW5 Wwh(v20) / Top Mount Refrigerator
Frigidaire RT114LCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD3 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD4 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD5 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCD6 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCD7 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH4 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCW1 Wwh(v1) / Top Mount Refrigerator
  #2 (permalink)
Old 07-29-2008, 10:28 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The vacuum and gurgling sound are a good thing, means you have a good seal. Now, your problems with the freezing of the evaperator will return unless you fix that. The reason it is freezing up is either your defrost heater is open, the defrost timer is bad, or the termination thermostat is bad. First I would check continuity of the heater to see if it is bad or not.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
refrigerator troubles taz2tweety Refrigerator & Freezer Repair 1 12-25-2009 06:10 AM
Freezer troubles Keli Refrigerator & Freezer Repair 3 09-09-2009 05:57 AM
oven troubles nhoj Oven Repair (including Ranges and Cooktops) 1 03-19-2009 04:51 PM
Bosch Troubles troywolfe1 Dishwasher Repair 0 08-06-2008 09:45 PM
Tumble Troubles Flamingstar Washer Repair 0 01-23-2008 06:28 PM
