Built in ice machine will not produce ice after cleaning 3 times.....water remained in reservoir after the last cleaning...not sure what that means:confused: It was suggested that I replace the bin thermostat but wanted to know why it sounds like the water is just running straight thru and draining. Pls. help!!:rolleyes:
