#13 (permalink) vbrep_register("234289") Today, 08:51 PM I purchased a used side x side freezer fridge and bought the a problem. Food is freezing inthe frig. Model PSS27NHMDCC Serial number RA424514 Reading other forum notes, It sounds like I may have a cold air damper issue. Frozen food and beverage in the fridge. Set point at 40. Actual temp at 29 and freezing everything but the beer. Other forums suggest to remove light bulb and look down the air channel. Problem is, I cannot seem to see down the air channel and view the damper working. In fact, I don't see anything but a cold air channel. Is this model/SN different? Any suggestions how to check and repair. Thanks Not so Handyguy on this one:) Handeeguy Revised: Took frig air channnels out and found air damper, broken of course. Superglued damper door and frig is working great. Food is cold not frozen and the beer is great. Handeeguy
