Discuss
Compressor not running
 in
Refrigerator & Freezer Repair
Hi, I came home found the frig not cooling. These are the steps I took. Removed back cover and saw
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor not running
  #1 (permalink)
Old 07-27-2008, 04:55 AM
Larchway Larchway is offline
Junior Member
Larchway is on a distinguished road
Default Compressor not running
Model Number: ed25texht02   Brand: Whirlpool   Age: 5 - 10 years
Removed back cover and saw condensor fan running.
Pulled connector off compressor and saw 120v there. (compressor warm)
Plugged back in and the thermal relay would trip every minute or so.
Put an amp meter clamp on one of the wires and saw it read 0 then jumped to 19amp then back to 0.
Is it safe to say the compressor has a locked rotor? The winding were around 6 omhs and 2.5 ohms.
Thanks for the help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-28-2008, 05:28 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Replace your compressor start device that's mounted on the side of the compressor (AP3083556)
__________________
  #3 (permalink)
Old 07-28-2008, 02:42 PM
Junior Member
Default
Ok. I was only able to get a Supco 3n1 relay device on a Sunday. Hooked it up per the directions to the run and common pins on the compressor and it still drew 19 amps then overloaded again. Does this mean the compressor is locked?
  #4 (permalink)
Old 07-28-2008, 05:25 PM
Senior Expert
APP Volunteer
Default
Your start winding is burn out or compressor stuck from varnish buildup=new compressor time/ new refrigerator. I always suggest a new refrigerator, replacing compressor would be more than $400.
__________________
  #5 (permalink)
Old 07-29-2008, 03:59 AM
Junior Member
Default
Well, the wife will be happy now that she can get the latest style "French Door Fridge". WE WE.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
When the air conditioner is not running, a fan is still running, why? yzhong Heating, Ventilation, and Air Conditioning (HVAC) 4 09-18-2008 02:59 PM
compressor johnc Refrigerator & Freezer Repair 0 05-21-2008 10:58 AM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 09:35 AM
Compressor not running julimarie Refrigerator & Freezer Repair 3 12-25-2007 03:41 AM
Freezer compressor not running thenninger Refrigerator & Freezer Repair 1 12-20-2007 03:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
