| » Removing Whirlpool Ice / Water Cover |
Model Number: ED5RHEXNL03 Brand: Whirlpool Age: 1 - 5 years
I need to remove the cover from this side-by-side ice/water unit. I saw one parts diagram for the back plate showing two hooks at the bottom so it appears that the top has to be released and then you lift up on the cover. My problem is to find out how to release the top. The local appliance store was not able to help. Any help will be GREATLY appreciated. I dont want to have to break the cover as Whirlpool says a new one is about 200 dollars w/ shipping etc. added. Thanks !
Saturday Morning update. Gene, I talked to APP yesterday and they tell me that the 'shell' is not available. I called Whirlpool and they say I have to buy the whole door. about $600 bucks - Do you know of any place that might have a used, (or new), one? If not I guess the only option is to attempt to repair the existing 'shell' . . . Dan'l Ads By Google Related Models Last edited by Dan'l Le Sage : 06-26-2010 at 06:55 AM. |
The instructions are attached to the reply. The new front cover assembly (#23 on the diagram) sold by Appliance Parts Pros for only $97.56.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED5RHEXNL03 Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
You are welcome Dan'l. Keep us posted.
__________________
Back again Gene. I got the cover off safely . . . MANY THANKS ! . . . The problem that I found is that one of the supports for the ice chute door's hinge pin is broken. As this is an intregal part of the black back plastic housing shell I will have to replace same.
Could you quote me a price for a new one and any sealant that I may need to use when attaching the new piece to the Freezer Door? (Any other parts or information or instructions that I need to change out this part?) Thanks again Gene ! Dan'l |
Ok . . . Thanks to Gene I got the Front Cover off. Then I determined that the back 'shell' was broken and tried to get one to no avail. (Would have had to get a new door and Whirlpool wanted 600 dollars for that).
. . . So, I was able to find a thin piece of brass to fabricate a part with and did just that to install alongside of the broken plastic strut on the 'shell'. It took a LOT of time and patience but I finally prevailed and the repair works as good as the new shell would have. 'reassembled the parts and replaced the cover, good as new. As my maternal grandfather used to say, "There is more than one way to skin a cat!" . . . Dan'l w/ Sentinel Services - Nautilus66@yahoo.com |
I'm glad you were able to fix it. Good job!
__________________
We got the front panel removed and aligned the ice flapper door back where it belonged. The right side plastic holder for the rod was broke off so we mixed some epoxy putty, formed it in a small rope and squished in around the existing plastic and the door pivot rod. We used a knife to assure none of the epoxy putty was on the white door piece that needs to pivot on the rod.
Thanks for the diagrams to help us get the cover off. |
| Display Modes | |
| Removing Lens Cover from Oven Light | renet | Oven Repair (including Ranges and Cooktops) | 15 | 11-04-2012 01:31 PM |
| Removing Ice/Water Dispenser Cover | tnt556 | Refrigerator & Freezer Repair | 0 | 06-20-2010 07:07 PM |
| removing plactic cover to replace control module | paulmnick | Dishwasher Repair | 1 | 04-27-2009 08:00 PM |
| Water Softner not removing water from tank | kysnake00 | General Talk | 0 | 12-01-2007 01:02 PM |
| removing cover off front of water/ice dispenser | need4help | Refrigerator & Freezer Repair | 1 | 11-02-2007 10:48 AM |
