I was having my kitchen remodeled and moved the refrigerator toanother room. there was no water supply and we plugged it in. I heard amotor run, but it stopped. later it was moved back to the water supply and we no longer producing any ice. do u have any idea what we need or how to fix this problem? Thank you very much, joan. :mad:
hi gene, yes, we do have water coming out of the dispencer and the water pressure is good.
its broken the motor when you pull out
hi pinoy, you told me that i had to replace the motor. Is that the entire ice maker or is there a seperate motor. Can you please tell me what part I will need to order and where is it located in the ice maker?
Thank you very much, Joan
