| » ge side by side freezer door no ice/water/light |
Model Number: tfh27prtbww Brand: GE Age: More than 10 years
freezer, icemaker fine.
door acts like no power. no water, ice, or light. already replaced spdt switch on frame. my wiring diagram is incomplete. |
Take off the hinge cover at top of freezer door, and inspect the wiring, making sure the wires and connector looks good, you can disconnect it and squeez the female ends a bit to make sure you have good contact when you plug it back in. If that does not fix the problem, then you will be looking at replacing the board.
Part Details - GE Control board, part number: WR55X129
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Pop off the front cover that says ice, water etc. behind that are 4 screws, undo those and the whole assembly will slide out, you will need to disconnect the wire harness attached to the board to remove it all the way
__________________
1 more thing I forgot, when you get the assy out, make sure the micro switch on the right side is being engaged when pressing for ice or water.
__________________
| Display Modes | |
| Maytag Side by Side Freezer Evaporator pan filling with Ice/water | holycownow | Refrigerator & Freezer Repair | 0 | 07-12-2008 06:30 PM |
| side by side ice and water in door not cooling or freezing | Anna1441 | Refrigerator & Freezer Repair | 0 | 06-26-2008 08:11 AM |
| Maytag side by side Freezer cold Refrig warm | timbruns | Refrigerator & Freezer Repair | 2 | 06-10-2008 06:11 PM |
| Kenmore Side by side getting warm freezer and fridge | tbonegrl | Refrigerator & Freezer Repair | 2 | 12-31-2007 03:52 PM |
| Amana Side by Side Refrigerator Freezer MFG. P1317202WE | josephbowles@earthlink.ne | Refrigerator & Freezer Repair | 0 | 08-10-2007 06:38 PM |
