Discuss
Freezer side works refrigerator side does not
 in
Refrigerator & Freezer Repair
Freezer side is staying cold 0 degrees to 5 degrees on thermostat setting 5. Refrigerator side will cool to 40
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer side works refrigerator side does not
  #1 (permalink)
Old 07-24-2008, 12:12 PM
deerhunter7719 deerhunter7719 is offline
Junior Member
deerhunter7719 is on a distinguished road
Default Freezer side works refrigerator side does not
Model Number: GSS22JFMCWW   Brand: GE   Age: 5 - 10 years
Freezer side is staying cold 0 degrees to 5 degrees on thermostat setting 5. Refrigerator side will cool to 40 degrees on thermostat setting 5. After a few days refrigerator side stops cooling. If you unplug the unit let it sit a while and plug it back in it starts to cool again.After a few days refrigerator stopped cooling again. Last night I removed back panel in freezer side and ice was covered on the evap coils. I defrosted the coils and the refrigerator side starts cooling again. Can this be caused by a bad control board or faulty defrost heater or defrost thermostat.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-24-2008, 12:41 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Most likely it is the defrost heater, you can easily see if the heater is bad by taking a continuity check of the heater, also at the top of the evap is a round disk, that is your termination thermostat, check if the blue top looks like it is pushed out of the housing. The heater is at the bottom of the evap and has a blue and pink wire attached to it.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 07-24-2008, 03:30 PM
Junior Member
Default
I checked the defrost heater and it has no continuity through it. I will get a new defrost heater. The blue top on the thermostat looks ok. Should I replace the thermostat since I am replacing the defrost heater.
  #4 (permalink)
Old 07-24-2008, 03:32 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
not really necessary.
__________________
  #5 (permalink)
Old 07-24-2008, 03:55 PM
Junior Member
Default
Thank you for your help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Side by side freezer works, fridge doesnt luvmyfam77 Refrigerator & Freezer Repair 2 06-16-2008 04:42 PM
Freezer side works but not refridg side atlanta404 Refrigerator & Freezer Repair 4 05-22-2008 06:24 PM
side by side refrigerator /freezer blows warm air truleygood Refrigerator & Freezer Repair 3 12-28-2007 03:19 AM
Kenmore Refrigerator Freezer Side By Side mchwalowski Refrigerator & Freezer Repair 1 11-28-2007 10:49 PM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 06:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
